Team Associated T5M Discussion
#2387
hello has anyone tried the brass D arm mount notice much of a difference with it? thanks
#2388
I built mine from the start with that brass weight, so I don't really have anything to compare it to, and mine still jumps nose down. I have plenty of steering in and out of the corners, and plenty of forward bite, from a dead stop I can nail it and it goes nice and straight. if I could get it balanced enough so that it would jump flat so that I would not have to do so much in the air to control it, it would be perfect for me, but like I said before only raced it one time, so I know I can tweak the setup more.
#2389
#2390
That is set to zero, I checked that.
#2391
#2392
Will give it a shot.
#2395
I think you use the 8.5mm hex.
#2399
R/C Tech Elite Member
You get 6 for the same price that others sell 4 for.
#2400
They are a standard metric 4mm. Last week I had one set where one axle was fine and the other had threads that were not quite cut to the end. Associated was good about sending out a replacement.
