Team Associated T5M Discussion
#2371
I added 25g behind the bulkhead on mine. Kept lifting the front under under hard throttle. Solved my problem.
Prob need to explain what kind of lifting you are getting? Is it more of a springing action off a jump or just flying nose high?
#2372
Running mine for the first time with the kit setup, I was really happy with it, and I did build it with the brass weight under the trans. I did notice when jumping that mine always seemed to want to jump nose heavy. I did opt for the square battery rather than a shorty which I believe may be causing a little more front weight. has anyone else noticed this.
#2373
#2374
I actually loved the setup, it did everything I wanted it to no problems, I have been racing a TLR Tenscte for the past couple years which is a 4x4 and loved it, so going to a 2WD was a bit of a learning curve as I haven't raced 2 WD for a few years. But the box setup other than the brass weight seemed really good. And since it was a square pack versus a shorty, I ran the battery to the rear with the thin, I think 7mm foam in the front. And I had the 4-gear trans. in it. Our next race it the 7th of November and I put the 3 gear in it just to see the difference and Ryan C. said he runs the 3-gear in everything of his, so I figured for less than 20$ in parts that I could give it a try.
Also wanting to try the VTS slipper #91175 if it is worth the money.
#2375
I actually loved the setup, it did everything I wanted it to no problems, I have been racing a TLR Tenscte for the past couple years which is a 4x4 and loved it, so going to a 2WD was a bit of a learning curve as I have raced 2 WD for a few years. But the box setup other than the brass weight seemed really good. And since it was a square pack versus a shorty, I ran the battery to the rear with the thin, I think 7mm foam in the front. And I had the 4-gear trans. in it. Our next race it the 7th of November and I put the 3 gear in it just to see the difference and Ryan C. said he runs the 3-gear in everything of his, so I figured for less than 20$ in parts that I could give it a try.
#2378
Our track is a well kept indoor, that is always med to high bite so the 3-gear should help me.
#2379
My only problem with my truck right now is that it has mid corner whip steering, where it will either break loose in the rear, or gain steering mid corner, and if I'm not careful I can oversteer a corner, has anyone else seen this? has happened at LRH, as well as Coyote Hobbies, which are both high bite slicks tire types of tracks.
#2381
#2382
#2383
if you have good forward bite everywhere else I would take some of the steering out. if you are struggling for forward bite as well then you can go shortest wheelbase if not already. inside hole on shock tower add a little more rear camber. lastly adjust roll centre in rear.
#2385
I really don't see any need for front weight, mine seems to always be nose heavy when jumping. and I got the Brass weight under the trans. But like I said before I run square battery packs which I am sure will add some front weight to it. maybe if I went to the shorty packs and ran it to the rear, then I might see nose up jumping.
