Team Associated TC6.2 Touring Car
#1216
The front and rear bulkheads are the same distant apart. if the rear diff fits in the rear, then it will fit in the front. if it doesn't then it's something you're doing wrong. check that you are using the same cams on both sides of the diff. they should be set to the same height on both sides and be in the same tension setting or your diff will sit at an angle.
#1218
Hello everyone,
My name is Steve Wang, owner of ST Racing Concepts (some of you that's been around here awhile, might remember me from old Speed Tech R/C days). We are looking to launch a line of titanium screw kits for the on-road racing segment. We are starting with a soft launch on the Associated TC6.2 sedan
http://www.teamstrc.com/index.php?ro...th=118_121_124
We are also offering a discount coupon code: rctech2014 for those of you that are willing to try one out.
Thanks and Happy Friday
Steve
Steve
#1219
titanium screws
Hello everyone,
Steve
Steve
#1221
Likely the screws on the bottom of the chassis. Changing these is counter productive and can be a bear to remove after awhile. The heads of Ti screws tend to strip out easily. I have another overseas branded kit on my car. I like them but I never use them on the bottom except where threaded into plastic.
#1222
I can certainly have a picture of the screw kit uploaded when I'm back in the office Monday
Steve
#1223
#1224
I got several trainings sessions with the bump toe configuration behind me now and want to share my experience with you:
I started it with a 17.5t setup. For this blinky stock class I can recommend the bump toe. I found the car easy to drive in an aggressive way.
For 10.5t or stronger motors the configuration only brought negative results on track. The car is a handful to drive; very inconsistent. The rear once has grip and then suddenly steps out. I did a direct comparison today and when I changed to the standard I was within a tenth of a second for more than 10 laps in succession and I was consistently 2-3 tenth faster. This just shows how much the rear bump toe setup disturbs your driving rhythm.
In the end you could say: Save your time and money
#1225
What about blinky? What times were you able to turn with bump to compared to normal?
#1226
That doesnt really help. How many 3x6 fhcs? How many 3x8 bhcs? Which screws specifically are not included for durability purposes. Thats the list that should be on the site. Right now it sounds like ur just buying the AE ones, re packaging them and re selling them. (No offense)
#1227
Meanwhile I worked on a 10.5t setup for the 6.2. I still want to do some more rollcenter and hex spacing tests, but this setup is close to the optimum. It allows early acceleration and turns very well while maintaining nice rear grip:
One thing I couldn't reach until now, is a rear end, that supports turning without sliding or oversteering. Something like the perfect balance, that I had in the 6.1...
#1230
Here is the link to the ear plugs, this is what Rick uses
http://www.drugstore.com/products/pr...rk=g&matchtype
TC6.2 MUCHMORE FLETA PRO MUCHMORE FLETA ZX 4.5
HITEC SAVOX SPEKTRUM
