Team Associated TC6.2 Touring Car >
Like Tree3Likes
Old 01-22-2014, 02:38 PM
  #451
DARKSIDE's Avatar
I cant say that...mine was a really good build and other than time, which Im always short of, lol...nice from start to finish
Attached Thumbnails Team Associated TC6.2 Touring Car-1.jpg   Team Associated TC6.2 Touring Car-2.jpg   Team Associated TC6.2 Touring Car-3.jpg   Team Associated TC6.2 Touring Car-5.jpg   Team Associated TC6.2 Touring Car-get-attachment.jpg
DARKSIDE is offline
Old 01-22-2014, 03:02 PM
  #452
JayBee's Avatar
Trader Rating: 31 (100%+)
That's REALLY unfortunate. AE has definitely been around the block a few times, so I don't understand the systemic lack of quality control. I wonder what percentage of defects leave the factory.
Like I said before, I went through my kit bag by bag....and it was perfect.
I've only built the spool, geardiff and shocks(gotta redo them as soon as my RSD stuff gets in) so far. The geardiff is one of the best I've assembled. There was a hint of flashing & 4 small circle indentations on the bevel gears, so I sanded all 4 w/600grit (this is prolly a bit compulsive, but it's my system)....after that, MONEY. The spool was fairly straightforward but the inside of the shock bodies could use some improvement....not smooth at all. Seems like the machining left behind from hogging them out. But once assembled, I didn't notice anything askew.
Can't wait to get back to it....
JayBee is offline
Old 01-22-2014, 04:54 PM
  #453
bhambrent's Avatar
Trader Rating: 11 (100%+)
Looking good Myron
bhambrent is offline
Old 01-22-2014, 07:24 PM
  #454
rc car guy's Avatar
with the wires running under your top deck, do they bit the battery and not allow the car to flex? Thats what happened with mine
rc car guy is offline
Old 01-22-2014, 07:40 PM
  #455
Use smaller gauge wire like 14ga. Mine is working fine
daveb is offline
Old 01-22-2014, 08:50 PM
  #456
DARKSIDE's Avatar
all 3 of mine are that way and if I may say...perfect....this past weekend at Thunder Jam I was 3-5 10th faster than the next driver...and the car was butter every round with the box stock setup minus -1.5 deg camber front and rear
DARKSIDE is offline
Old 01-22-2014, 08:52 PM
  #457
DARKSIDE's Avatar
Originally Posted by bhambrent
Looking good Myron
thanks...I really think this is AE best
DARKSIDE is offline
Old 01-22-2014, 09:19 PM
  #458
Adonis_mp's Avatar
Trader Rating: 9 (91%+)
Looking to lose some weight, has anyone tried a shorty pack, 4200mah?
Adonis_mp is offline
Old 01-22-2014, 10:13 PM
  #459
YoDog's Avatar
Trader Rating: 28 (100%+)
The car is already close to legal weight as it is besides, the balance will be off from left to right unless you have a shorty motor to go along with your shorty battery. Lol
One the most effective ways to lose weight is to run a light weight body.
YoDog is offline
Old 01-22-2014, 10:52 PM
  #460
R3VoLuTiOn's Avatar
Trader Rating: 29 (100%+)
ORCA TX motor
R3VoLuTiOn is offline
Old 01-22-2014, 11:24 PM
  #461
evochick's Avatar
Originally Posted by R3VoLuTiOn
ORCA TX motor
+1 this nearly caught me out when i swapped the Reedy out
just make sure you leave the fan on after the race for a while, i think the can suffers from a little more heat soak after a race due to the material used.
evochick is offline
Old 01-23-2014, 04:55 AM
  #462
rc car guy's Avatar
Between the orca tx motor (10-15g) and the battery thats around 300g orca ultra ifininty 6200 cough a lw body and lw paint job the lw body is worth about 5-10g the paint is worth about 20-30g I had to add 42g to my cars chassis to make 1380
Old 01-23-2014, 08:30 AM
  #463
speeddaddy's Avatar
Originally Posted by chiefj48
Well I feel your pain!!!
I wonder how many others have had the same problem???
Now that it is built, I love the 6.2 .This car is planted
speeddaddy is offline
Old 01-23-2014, 07:53 PM
  #464
JustWill75's Avatar
Had a great week with the TC6.2. Wednesday night finished Third in 17.5 and that was due to my own driver error. Did a little spring testing with Reflex, ARC and Yokomo Springs. I have to admit I really like the Yokomo Pink front and Blue rear. I did notice that in order to run them I had to use a different spring perch. I also noticed that even with the collars all the way up my ride height would not go below 5.5mm. For my track 5.5 is where you want to me but I still would like to know what is the best way to get the yokomo springs to work on the TC6 shocks? Note: I have not tried Reflex's new TC6.2 springs yet. I will order them soon.
JustWill75 is offline
Old 01-24-2014, 04:24 AM
  #465
TJames987's Avatar
Trader Rating: 11 (92%+)
Default Arm mount inserts qtn for the pros
Hi I’m really confused about these arm mount dots. The kit setup has you use 1 one dot arm mounts which = 0 degrees. How does the rear end of the car get to 3 degrees of rear to using the one dot arm mount inserts?
The new setup sheets are kind of confusing too because they indicate inner and outer arm mounts for the arm mount inserts. I’m assuming inner means the mounts toward the centre of the car… What affect does changing the arm mount inserts in the front have, why not just adjust steering links?
Anyone else confused about this?
TJames987 is offline
