New Novak Brusless System
#1441
Our local track (Kansas City) is going to have a big race in December with a Brushless 4300/LiPo class. We have a pretty decent following for it locally and hope to get some people around the region out to join us. Foam tires, Ozite, sedans... you know the drill. We're going to allow the 13.5 in our stock class as well. Come on out, show your support for brushless RACING.
http://www.fastlanehobby.com/flyers/nats2006.pdf
#1442
Revelations race way in Montclair, CA is hosting a three day race sponsored by Kyosho on 9/22-9/24/6. I thought that this track would be perfect to show what the brushless motors can really do.
With the speeds that the brushless motors are reaching maybe its time to try it at a slightly larger track. lol
#1443
Is the sintered rotor legal to use in and Roar or IFMAR events?? If not when will the rotor and the 3.5 be legal to race with.??
#1445
Fellow Novak users
Should there be any play in the rotor on a 4.5r? By play I mean in and out motion.
Do your motors have any play in them?
#1446
#1447
Are they AARCMCC legal?
#1448
Fellow Novak users
My 5.5R was about the same.
They all seem to have a decent wiggle to them...
#1449
Yeah all of them have it, even the 3.5. It doesn't seem to do much although I've noticed when the motor is reved the sharft moves further into the motor then when the throttle is released the sharft moved back out. Maybe this is why the movement isn't shimmed out as it would cause drag and slow the motor down when the sharft moves further in.
Drew.
Drew.
#1450
Hi All :
Do you know If use 3.5R or 4.5R in Cyclone use which gear ratio ?
Thanks!
Thanks!
#1452
Originally Posted by LeoChan
Hi All :
Thanks!
Thanks!
FOr the 3.5 - ask someone else.
A note on the 4.5: It likes to gear down. 10 and above is good.
#1454
Moderator
I have some problems with my Novak 5.5.
The motor shuts down after a few minutes of heavy running.
I have tried the entire range of rollouts, and the problem persists.
I also run an extra fan on the motor.
It shuts down at approx 80 degrees celcius, which looks to me as well below the temperatures at which damage would occur. Does anyone know any tricks or suggestions? Does anyone know if you can bypass the temperature sensor on the motor in any way?
#1455
Trader Rating: 51 (100%+)
Hello There Pro Ten Holland
I cant confirm this but if you cut the blue wire I believe thats the thermal temp wire
Hope this helps
Mike
Hope this helps
Mike
