New Novak Brusless System
#2236
Yeah, its got no motor limit, im running a stock motor on it. U have to remember to do the ONE TOUCH SETUP with no motor or sensor wire connected, then change to brushed mode, then connect a brushed motor.
#2237
Originally Posted by VooDooPH
is it OK to use a dean's connector? I'd like to be able to switch from brushed to brushless easilly.
Look at the third pic under the center shock, you'll see where I slice the red wire for the positive connection to the motor.
#2238
Originally Posted by rcgen
It's ok us a dean's connector but you'll have to modify it for the three wire setup. I use a 3.5mm bullet connectors and switch from brush to bl all the time. I have posted some pic on the RDX tread but can't find it. Here's a link to some pics of my oval car with a bl and brushed motor. http://www.hobbytalk.com/bbs1/showth...&page=18&pp=15
#2239
In the brushed mode I hot wire the positive to the motor and battery. In brushless I normally hot wire the positive brush wire to the positive battery or sometimes unsolder the jumper wire
#2241
Originally Posted by B18C Turbo
Help! I don't want to run that insanely large power cap on my new GTB. I have no space for it on my touring car. That is such an awful design, why does Novak do this? Look at the size of it, its the size of the whole ESC. Can I run the GTB without this power cap?
this question has been asked several times before, do a seach on this thread and you will certainly will get a proper answer on that....
#2243
Company Representative
Here is an article from TeamNovak's website explaining capacitors (includes a photo):
Power Capacitors and Capacitor Modules
Reading the info probably won't make you any happier about running the module, but you may see why Novak stands by their "awful design."
#2244
#2246
Need help, is it possible to replace the fan on GTB with the fan that comes with computer at the top of chipset heat sinks........?? i've been trying to buy the novak one but it's out of stock and i do really need one.
#2247
voodoo,
All of my GTB's are the NON Spectrum type..and I run Spectrum radios in ALL my cars.
It's my understanding you can run the NON Spectrum W/ a spectrum radio, but not vice versa.
The Spread Spectrum ESC's have a faster switching optimizing the Spectrums ability and this feature also lets the speed control run cooler.
DRAG-ON
Check With NOVAKS site for the fan
Shop At Team Novak
DRAG-ON
Shop At Team Novak
#2248
#2249
@DRAG-ON
Have you try Muchmore fan, its slightly smaller (25x25mm) than novak fan (30x30mm), but its true 5V fan,
airflow is almost the same, I think it can replace original novak fan
#2250
wat FDR would u recommend on a GTB 5.5r (sintered) with a cyclone? Also is it possible to limit the speed on it?
