F201
Old 04-25-2003, 09:38 PM
  #436
rto997's Avatar
Actually you can use any gearing that was designed for the F201....hence the two gear sets stock or the high speed. The guys at Tamiya have been running the Monster with the High speed down there!! With no problems...does come off the track a little hot...but so far no explosions!!
rto997 is offline
Old 04-26-2003, 06:41 AM
  #437
I use the MTroniks Tempo ESC w/1-touch setup and it works fine with the stock kit supplied motor. I recently put in a Kawada 12T in my F201 with the stock gearing. It takes longer for the 12T to spin-up than the stock motor. With the stock motor, power is on tap instantly. With the 12T, it takes over 30% throttle before the motor spins up. Is it because it is overgeared? The Mtroniks Tempo is rated at 12T and over. I use TowerHobbies 1500mAh sports packs.
Morpheus2be is offline
Old 04-26-2003, 04:41 PM
  #438
psycho's Avatar
Morpheus2be
Yeah, you're overgeared for a 12T motor. You should be somewhere around the 9:1 range for that motor to perform well. You run the risk of burning it up with that low of gearing.
psycho is offline
Old 04-27-2003, 05:11 PM
  #439
I found out why the 12T isn't spinning up as fast as the stock motor....it wasn't getting enough amps! It turns out that my 1500mAh sports pack wasn't fully charged. I put in a fresh pack and the 12T motor spins up instantly. That only last 2-3mins though ....
Old 04-29-2003, 11:31 AM
  #440
rc-zombies's Avatar
Just received the Williams BMW FW24 body set from Japan. Detail and decals set is awesome...the body looks so much nicer than the Farrari. Can't wait to get it painted and mounted. The matching Wheelset looks equally good...
rc-zombies is offline
Old 04-30-2003, 09:28 PM
  #441
psycho's Avatar
I agree. I was one over the weekend. The front wing looks trick! My old one is still in pretty good shape, so I'll wait until they are released in the US.
psycho is offline
Old 05-01-2003, 08:01 AM
  #442
rc-zombies's Avatar
F1-RC has them on pre-order...
Old 05-01-2003, 10:55 AM
  #443
Aluma's Avatar
y'all think that new williams body would fit the F103-RS ?
I love the new shape...
Aluma is offline
Old 05-01-2003, 10:56 AM
  #444
rc-zombies's Avatar
Probably not...the F201 has a longer wheel base.
Old 05-04-2003, 09:18 PM
  #445
black-knight's Avatar
is there a front one-way available for the F201? Tamiya or Third party?
I was thinking that a TBEVO unit might fit?
black-knight is offline
Old 05-04-2003, 09:22 PM
  #446
BigDogRacing's Avatar
Trader Rating: 12 (100%+)
Attention all TCS racers that are coming to Memphis-
Our AMB r/c and Jlap software is working well. If you have personal transponders please bring them. We are proud to announce this new system and software!!!
Please spread the word about the TCS race. We would LOVE to have all of you!!!
BigDogRacing is offline
Old 05-05-2003, 12:44 AM
  #447
veecee's Avatar
Trader Rating: 34 (100%+)
BK: Tech Racing has one - FP2007. Bought one last yr from Japan but yet to install...
veecee is offline
Old 05-05-2003, 02:54 AM
  #448
thanks! veecee! btw: u ready to race again?
Old 05-05-2003, 08:04 AM
  #449
rc-zombies's Avatar
yes...Tech Racing makes one..
don't know if the TB unit will fit...
check out the option parts at:
http://www.formula1-rc.com/
Old 05-06-2003, 10:52 PM
  #450
veecee's Avatar
once i sort out a new toy (MR4 SD?) and find some time to mess around with it... then i have to think about new packs (3300) and motors (brushless?) as my source has virtually dried up...
veecee is offline
