TLR 8IGHT E 3.0 THREAD
#1411
It's on the TLR site!
Basic setup: http://www.tlracing.com/ProdInfo/Fil...dard_Setup.pdf
Blank sheets: http://www.tlracing.com/ProdInfo/Fil...lank_Setup.pdf
#1412
Anyone have any pics of their car ready to run?
I was looking at my wiring last night and routing, just curious how a few of you have set yours up? Forgot to order a longer sensor wire so looks like another week before I can get out and run it. Also, where are you mounting your transponder with the radio box? Anyone running a HOTWIRE?
Other than soldering and painting the body, I'm about ready to practice and start racing again..
http://www.rctech.net/forum/electric...thread-57.html
In post 844, you can see some pics of the wiring in my E 3.0.
I have the transponder in the receiver box to have as few wires exposed as possible.
#1414
Look in this thread:
Any problems with the transponder mounted inside the receiver box? I didn't think of mounting it inside, wasn't sure if the signal would work that well inside..
#1416
On page 44 in the E 3.0 manual, there is a depiction of the receiver box wiht a transponder and a receiver:
http://www.tlracing.com/ProdInfo/Fil...002_Manual.pdf
I have it in the same way.
#1419
What battery packs do you use for the losi 3.0?
#1420
I use several type of lipo packs, because I buy when I see a good offer or if somebody at the track sells some cheap.
But, I have 4 cell 5000 mah lipos, pairs of 2 cell 5000-6000 mah lipos and pairs of 2 cell 4200 mah shorty sticks lipos.
I try to have packs with at least 40-50c discharge, but I have some Turnigy's with 35c discharge (75c burst) and I have not had any problem with them, despite of the lower c rate.
#1421
Tech Prophet
Depends on where you are running and the motor. For indoor we are running light setups with either 2 shorty packs or a light weight 4S and the T8i motors. For larger tracks or longer mains (over 10 min) you will probably be looking at higher Mah 4S packs and T8 Gen 2 motor.
I am running dual Venom 3800mah 60C shorty packs with the T8i as I run indoor mostly.
#1422
I wonder how a 1258 servo on 6 volts would perform in this buggy
#1425
NOW WERE TALKING!!!!!! That is it.. Do they have one for the E buggy???
