TLR 8IGHT E 3.0 THREAD
#871
Question about setup on the 3.0e. On a large hard packed covered track (Mike's in Houston) what would be the best setup to run? Stock or the Drake indoor setup on the website? Been a while since I have run 1/8th scale so I'm looking for a somewhat neutral setup to start with. Any other setup tips? Thanks.
#872
#876
#877
#879
Is this the arm, or is their a new one for the 3.0?
#880
That's it!
#881
Are you guys upgrading to the aluminum upper steering plate or is there a downside to running it over the plastic one?
#883
Its a little more weight on the front end which is a tuning option. Some have said it makes the steering feel a little more precise on high bite surfaces because of the reduced flex.
#884
Hey guys have a quick ? My rear diff is out to change fluid and I noticed that when I spin each outdrive it feels free but say I hold the diff housing and try to spin one outdrive its locked and won't turn at all is that right?
#885
Some thing is wrong inside there it should turn doing it that way too. We did have a broken diff cup on the front last spring and it was acting that way. Make sure the metal insert on the cup side isn't coming loose from the plastic.
