Tamiya TA05 Touring Sedan
Strong, I will be putting in a order soon too!!! I was so impressed with this car I ditched the old xrayroooahhhh signature on here for a tamiya logo and different name!!!
I'll try the springs and get some spares to start with....I think a double fan to get some extra gearing into the car.....and I'll try some Hpi Advan carpet tires next time out!!!!
R
R
As far as upgrades........I just received an order yesterday and replaced both plastic diffs with metal........The plastic are fine I just think I did not tighten one of them enought.......I also have front universals and a kimbrough servo saver.......I did have yellow springs but went back to the silver........To me the car dont need much upgrading....Might try front oneway.
Well......second race night tommorow.....picked up some springs....and I am updating the Tekin (needed more speed!!) I'll update when I get back from racing!!!
Any news on your ride Strong??
R
R
I have an issue with front ride height, I can't get it below 7,5mm.
I use Tamiya TRF dampers.
Should I use the shorter springs ?
Yep....shorter springs and adjust the collar on the damper for ride height...
R
R
Suspension blocks
New to Tamiya T05-R
I understand the differnece between the inside block and out block sets toe
1B-1A = 0.5 toe, but what does the XB signify? I noticed the X_ are straight while the 1A is a bridge. Was the X_ just to lower the COG of the block?
I have a TA05 and use the blocks that are supplied with the TA05R kit.
The cog is adjusted by using shims (they can also be used to set anti-dive and anti-squat).
0.5 degree difference between each block.
Widest to narrowest goes
E, D, C, B, A, X, XA, XB, XC, XD
Is there a manufacturer that makes a top deck that is still available ?
Suspended
The XB should create somewhere around 0.5° toe-in for the rear suspension. Using the XB mount in the front w/ bridge mount 1A will create toe-out on the arms. The XB mount is primarily used on the TRF415 series, but you can use it for the rear only on the TA05-R.
Just wondering if anyone can help....
The question is on sway bars.....we run on carpet (primarily) just wondering if anyone has found the sway bars to help....needed....and mostly what they in theory do for the handling of the car....
Thanks in advance,
R
Thanks in advance,
R
Suspended
Not for the Tamiya chassis; no way to mount even a custom upper deck b/c the motor mount is in the way. Can't design it to go outside the mount as it will whack into the motor itself. Also there's no way to tie it into the front bulkhead w/o tweaking either the upper deck itself or the front chassis brace.
You can always buy the 3Racing carbon fiber chassis kit, which comes with an upper deck. But then again, IMO it's not a TA05 series any more; just another aftermarket kit that happens to have a few Tamiya parts attached.
I've kept my R completely stock, and it's fine the way it is if you ask me
Suspended
Without sway bars, the car's weight slings in the opposite direction of the turn, and reduces traction on the side of the car that is going in the direction of the turn.
Oh yeah - by the way, they do help. Throw a set on, and watch how easier it is to control the car diving into a turn
Thanks for the quick reply.....do you have any experience as to what color to use front and back??
R
R
Stabilizer bars help the car stay flat during cornering; i.e., they prevent the car from rolling side to side. The thicker the sway bar, the more it helps keep the inside wheels during a turn planted on the ground.
Suspended
I don't quite know how your radio is dialed in for steering, so I would recommend starting out with the factory settings; med for the front and soft for the rear, and then go from there. They set the rear softer than the front so that the sway bar doesn't fight against the shock springs in the rear as much, and lets them do their job keeping traction and push for the car.
I push down each shock, one at a time, and check to see if all the tires are still on the ground. This shouldn't be a problem, especially for any of the TA05 series though.
Red = soft
Yellow = medium
Blue = hard
Anyways its a good place to start. You can first dial in the steering, and if that's not enough, beef up the front w/ a heavier bar.
