Tamiya TA05 Touring Sedan
#991
Originally Posted by Jam-ehz
Is the battery holder the same as the TB-02? Maybe the TB-02R CF plate will fit..
However, TechRacing one is lighter...
#992
I installer the tech batt plate last night, simply dremmelled the posts whitch the retainer srews go in down a few mm, now you can adjust the height so that it hold the cells securely.
I also put on the Tech low top deck, and was a bit bummed that you can no longer access the battery corally plugs, if you orientate them on the inside of the chassis, and the cells dont sit flat if you orientate them towards the outside. I guess i will just have ot plug the rear connector on before i insert the pack, the forward corally plug can just be installed.
#993
hey guys, im in the midst of saving for a touring car and am unsure what car i should get, im thinking either a mi2 s1 or a ta05, im veering towards the mi2 as it comes with cvd's, better shocks, dual deck, stabalisers, but am still undesided so any thought would be grealty apreciated
thanks,,, 180sx
thanks,,, 180sx
#994
front sway bar
I am having some problems trying to install the front sway bar correctly. I followed the instruction and clipped the inner corner of the front upper gear case and installed the sway bar per instruction. Without mounting the front shocks, when lifting one front arm, the other arm doesn't move up like it should. And both front arms become very stiff with the bar (yellow one) on. However, the rear sway bar seems to work fine and no binding whatsoever. Any help will be greatly appreciated.
#995
Hope this helps!
#996
thanks,,, 180sx
thanks,,, 180sx
You may not have the same options as I had but still enjoy the end results!!
Good Luck!
#997
dongskie
Originally Posted by Dongskie
Hi! I would gladly suggest you use a 102t/64pitch spur gear, this would give you more gear ratio choices. On a 27t motor use 35t/64p to 39t/64p pinion, on a 23t motor use 33t/64p to 37t/64p pinions. The lower pinions will give you better acceleration, eg. on a technical track.
Good luck!
Good luck!
TNX dongskie. been wanting to go home to PI, How are the tracks there? asphalt ba or carpet? where do you race? Its been a long time since I've been home miss the Pinas and all the beautiful Pinays.
question.
suspension blocks, which one to use? for the front and rear. What does it do? is it for roll center?
#999
#1000
Originally Posted by maxepower
TA05 is cheeper then the MI-2, but you will have to buy hop-ups at some point. . . .
Because he is new, he will have a lot of breakage. In which case he will be able to replace the parts as they break with better parts. Note that even the best cars break. In fact, the suspension of the TA05 is one of the more durable available because it is a softer material version of the suspension arms, which are thicker than the latest and most competitive arms, yet in time, he will be able to upgrade to the better arms -- which are already available. Buying a more expensive car will generally not stop you from crashing (a more expensive servo will sometimes reduce crashing, but generally not the rest of the car), nor will a more expensive car generally be more durable.
Also, it is beginning to look like properly upgraded and setup TA05 can be competitive with cars very close to the best available.
#1001
Originally Posted by dragracer72nova
Hello,
I am new the the TA05.
I am wondering if I can put a 64 pitch spur and pinion combo in the car?
I am running stock rubber?
OR do I have to run the 04 gear setup
Thank you for the help!
Dave
Dave
With that, I have a range of 28 to 41T pinions (I have them so low because of my 1/12), but use 41T for Tamiya Sport Tuned motors, and 35T for 19T.. not sure about stock, though...
Or, if you want to stick to metric .4 gears, the TRF415 102T spur will fit, or the Evo III/IV spurs. The TA04 ones are too big, though.. 105T is the max (106T may work, but is pushing the clearance limits of the chassis), and Tamiya will be releasing their own TA05 105T Spur gear sometime...
#1002
Just finish a race (doesn't get good score, human error ), and here is my car after race.
Car weight with IB3600 cell, Rayspeed Accord body, 1523g only, just made our local rule 1525g everything on.
Gonna order mid one-way and front one-way next month, so it will get a bit heavier
#1003
hey ttso,
where did you get your carbon fiber top deck? does it make the car stiffer?
did you race on carpet?
#1004
Originally Posted by cheehtae
hey ttso,
No, I race on asphalt only. Using the 2F will make the traction fade a little, but I like the solic feel...
