Tamiya TA05 Touring Sedan
#5269
Question on turning
Does anyone have any problems with the turning radius of their TA05. For some reason my turning radius sux. I have the front toe-out .5 degree should this be more ??
#5270
#5271
I'm running a stock servo and my turning ratio is good. It's almost too tight when I'm racing. I can flip it around at any time. I had the stock rear hubs that are #2 and I just put on some 3 racing 0 degree ones so this should help me out with better high end speed correct?
#5272
turning
Originally Posted by JayBee
What radio are you running? Is it able to adjust EPA (end-point adjustment)?
im using a spektrum dx2 with the spektrum servo. I have the steering set to 100% i guess i could try it at 115%
#5273
have a look at this website it will help with setting up and what settings do what it really helped me out when i had problems. got to touring car setup http://users.pandora.be/elvo/
#5274
#5275
Originally Posted by CIVIC91
I have been using mine for a few weeks, both 19t asphalt/rubber and brushless/carpet/foams. They do seem to free the drivetrain a little more and have not skipped once. Pretty nice cheap hopup!
#5277
Originally Posted by buboy28
Steve, would like also to order but cannot find it at your website, thanks
Steve Wang
#5278
Originally Posted by SpeedTech
Wide pitch pulleys sorry guys, TA05 have too much hop-ups, it's at the bottom of the page. And we only got a handful in this shipment.
Steve Wang
Steve Wang
#5279
Someone please kick me in the jimmy!!!
I just installed my new blue belts and I replaced all the stripped alloy alan heads with the normal ones. I got excited and stuck in the 4300 pack to give it a blast in my warehouse.
Then someone opened the door and I turned my head to look at who it was. Next thing I hear is a cracking sound.
I ran straight into the parked forklift forks. Broke the front suspension block and the rear front block, bent the shaft that holds the arm on and worst of all, I lost one of my TRF shocks somewhere. Plus the small little plastic pieces that go on the shaft to help keep the arms from moving.
