Mugen MTX-4
#9016
I'm running a stock Mugen and I have never stripped a gear. Well the one time I did, my mesh was off. It was still one spur gear after the many months of owning the car. Not only that, but I manage to stay with all the other high end motors on the track. Still a bone stock car.
#9017
Suspended
Ryan C: What set up do you have or I can use for speedworld? There is one that was posted from yllib back a few months I saw, is that a good one?
Thanks for the help
Thanks for the help
#9018
Nitroballer9, Billy and I have the exact same setup and it works pretty well so you should be good with that one. I can email/pm it to you if you want. Any other questions fire away!!
#9020
R.C. I will have the ybslow products in the store in about a week, Brad is waiting for some of his products.
Billy
www.speedworldraceway.com
Billy
#9022
#9023
another question, my side belt seems very loose. I have the right pullies on it as far as I know. Use a 24tooth for the front side and a small one on the rear side. I have the tensioner set all the way down and it still seems to loose. Alot more than my rrr's side belt. If it makes any diiference its a mtx4r and Im building it. mugen really needs to work on there instructions, they are one of the worst I have ever seen
#9024
#9025
You have it right. The belt is pretty loose. You can do a little bit of notching but it will still be loose. Regarding the instructions: Get used to it. Most of the manufacturers instructions stink.
#9028
tony montana: I have had the same problem with the side belt slipping off the side belt tensioner, so what I did and it help a ton and really did not add any friction, but tighten the belt a little more was, run a 1/8 scale serpent 24t pulley and the serpent alum adapter on the side. The gear in larger but still a 24t and the belt pitch is the same.
I have not had the problem since.
