Kyosho Ultima RB6 & RB6.6 Car Thread
#3286
just made the switch from 22 to RB6, so I'm 100% k-car
#3287
@eper
I am going to try your setup for the shorty. Why did you jump to red front directly? How did the whites feel with shorty all the way front? I do like more steering than most, whether that makes me fast or not is another matter, does make me happier with my car . Just afraid reds will take away a lot more steering.
I have both white and red to try and thinking of going to white first.
Last week I found more speed with my current delta rc winter track running a full 300 gram lipo with pink/gold since the track is super rutted from 1/8 nitro and has fewer twisty bits than the summer tracks.
#3288
better battery support
if you are using a short pack i found an easy way of making a shorter battery hold down . if i wanted to use a fan i could .on the rear all you need to do is use two ball cup ends long . cut the length flush just under the ball cup side . trim so it will fit down in the middle hole of the battery holder put a counter sunk screw in the bottom to secure . on the top drill holes on the top and reinstall the top support cut the battery top brace to length . real easy
#3289
Well finally finished my build and all I can say is....I haven't been this impressed with a kit since my last X-ray build. The car went together very nicely and i was pretty much able to hide the majority of the wiring. Waiting on my Esc to come in before I get to toss her on the track. I did start my shock setup with 1.6 2 hole pistons f/r with 32.5/30. On the bench it feels a tad soft but might work.
#3290
Kyosho Released UM720B SPSP Front Sus. Plate Type-B (RB6/RB5/RT5). Anyone know what this does?
#3292
Thanks for the PM's regarding the stickpack/MM config guys! I think I found a pretty elegant solution. Hopefully it will help anyone else with the same problem. I used the rear battery mount and slid it up against the posts in the rear. Sponge taped it to the chassis and everything fits perfectly.
#3294
#3295
I've somewhat been following this car since it came out. I used to own a Rb5 WC and well... nothing compares to k-quality. I was wondering how agile is the rb6? Also is it durable? I would be running stock 17.5.
#3296
I just got one for 17.5 racing, I love the car very agile and responsive, I run Shorty's not sure on stick. I've only broke a RF2 plate so far and I hit the pipe pretty hard but didn't even know it was broke and won the race. Just be sure to use the thicker Rf2 (had smaller one when broke). I herd the steering bar can break so im carrying a spare but so far so good, going to order a exotek if it breas. I've drove both B4.1 all the hop ups big bores, tlr 22 hopped up. My opinion is this car is amazing and drives like no other very smooth.
#3300
I must be missing something as to why your going through all the trouble to use long ball cups cut off etc etc. My battery is setup like yours with the parts from the kit. The kit included parts to set it up just like that.
