Yokomo MR4TC-BD
#2431
Originally Posted by Hebiki
ok.. cus i remember using the delrin diffs from the EvoIII in my 415 awhile back and i had it shimmed 2mm or so. didnt want to do that again
curious if the 415ms delrin diffs would work with the BD?
#2432
Originally Posted by pops
I thought someone on this thread had tried that earlier and it didn't fit on the BD?
But they are very smooth, but with ceramic or tunsten diff balls a standard diff can be just a smooth. Just my $0.02 on the delrin diff subject, Oh the HPI is much more durable although not as smooth. IMO
Stephen <><
#2434
as a direct fit the MS delrin diff is too wide, but gradually removing material from the stepped lip where the output begins to widen to the diff ring support, on the short side, is enough to make it a near perfect fit
#2435
Is the spool to wide or the bulkhead?
#2436
it is the width of the diff that is too wide, but now as im trying to properly build the diff back up, i seem to be having problems with the internal parts fitting/working, will try an work it out though
[edit] ahh, found the problem, where the inner ballrace fits into the short part of the MS diff (the ballrace is in the long side on yok diff) doesnt go deep enough into the output so the diff plates cant get close enuff to contact with the balls.
hmm this is turning out to be abit of a hassle to do, seems like alot of work, should lok good once its finished though
#2437
R/C Tech Elite Member
Originally Posted by Chris Brown
I was looking at pictures of some peoples' BD's and noticed a few have mounted the steering ball studs upside down. I have two questions about that; one is why and the other is when you do that, do you still put the 2mm spacer on the steering rack? Thanks.
#2438
Originally Posted by Randy Caster
It just corrects the cars bump steer, gives a little quicker steering reaction from what I felt. You do not use the 2mm spacers if you flip the links.
Stephen <><
Guess I need to go work on mine...LOL
#2439
Cool, thanks Randy. I already did it with and without the spacer, and with the spacer looked totally wrong, but I wanted to ask anyway. I saw on your RROC BD that you didn't have a power cap or that you hid it well. I use the QC2 and plan on using the cap but I just wondered what you thought.
#2440
I honestly dont feel the difference between running the cap and not running it, I didn't suffer any glitching from loss of power to the reciever or anything, so I may just keep it off.
Matt Francis actually says you get more punch with the cap off on the QC2.
#2441
after much trying, TRF 415 delrin diff doesnt fit, the driveshafts are too long to fit in enough
have heard though that the LCG dogbones are shorts so might fit, this seems alot of trouble to run a delrin diff though, will try the LCG stuff sometime...
#2445
Since I am in the question asking mood and people love to show there knowledge I have one. When and why wouldyou run a direct center pulley verses the one way and why the hell would they have a center one way if you havea front one way. Life was easier with 2wd offroad. I counldn't even say pulley until this car.
