Hot Bodies Cyclone
Yes the cyclone diff bolt is a known weekness. A good fix is to go with the larger screw from associated or switch to the new pro spec diff. A large problem is your diffs are probably set too tight. Also switch to a spool in the front running usvta the car will run better
Tried a spool in the front and didn't like the handling at all. Maybe the grip of the track wasnt high enough yet, or my setup is way off for a spool to work. Also, it's an aluminum spool and the steel drive pins on the front CVDs really chewed it up and left deep notches in the spool.
Setup / tweal plate
For those expressing interest on the Cyclone setup / tweak plate...here are a couple of pics of completed plates. I should have these ready for sale on Wednesday @ ppdbillet.com. This is a limited small run based on interest of PM's and our thread so dont be surprised if there gone in a couple of weeks.
Nice job Kevin.
TC in pic above will be up for sale as soon as I get it back from Verndog.
Pm me if interested
Pm me if interested
Korey , i have had this probleme for over 5 month so the changes that you told me to try did not afect the cornering speed , ( when i had 2mm under camber link and now 1mm under camber link it did not make the probleme worth) .
I had few problem like rear end loose and know resolved , funny noise with universal joint now less noise .But know i have to get a bit more cornering speed.thats my probleme know.
So know id like to know how to improve cornering speed?
hey
i just oreded one of these new cyclone TC could any one tell me if the trak power 5400 lipo fit
cheers
cheers
I will have to order the pink spring.
thanks Korey for all the help EJ20 .
Help needed
I have just installed the HB sway bar stopers to stop sideways movment of sway bars, now they rub/jam on the front pulley.
I have the 18t pulleys with the diff holders pointing straight down.
any idea's on how to fix this problem?
You need to use the standard plastic roll-bar guides, other manufacturers alloy ones sit the bar too close to the pulley to use the stoppers.
Is the Cyclone S kit a good kit for racing? and what what be needed to up grade it to running with the bigger name car brands?
