Hot Bodies Cyclone
#9662
#9663
URGENT!!
Anyone got an editable cyclone setup sheet please
Cheers Malc
#9664
#9665
#9667
thinking of getting a Cyclone S RTR for the girlfriend...how can i hop this up and make it Moore Speed Spec? What parts do i need to slowly, say again, slowly hop it up? where can i get the chassis? are the parts for the Cyclone the same as the HPI Pro 4? thanks
#9668
thats a good buy but hopping it up to be a moore speed spec is going to be a lot of work weather you do it now or later slow or fast why not try buying the normal cyclone with the carbon chassis and start from there imo much easier and you are half there,some of the parts on the pro4 will fit the cyclone.cheers
#9669
Just run the Cyclone S as it is, as mentioned dont bother trying to hop it up it would be easier and cheaper to buy the moorespeed kit.
For the S replace the C hubs with the proper carbon graphite ones (like on the full moorespeed/pro 4, the ones in the kit will literally break in your first or second race meet.
When building the shocks make sure the shafts dont bind in the ends of the shock caps, if they do ream them out slightly.
The only other thing to look out for is if you upgrade to a spool or oneway you have to upgrade the entire centre pulley system so that the front belt uses a proper metal centre pulley, the plastic ones will strip otherwise.
#9670
the reason why i wanted the the RTR version is because she doesnt have any radio equipment!! At least the low end stuff will get the car going...so what's the chassis i need for the RTR to at least get it going?
#9671
You could do the cyclone, and a cheap radio, used if you want it really cheap...
I would shoot for the cyclone, and then theres no upgrades needed, well maybe some things you think, but it has all the al and graphite parts
#9673
Replacing the decks has the added advantage of lowering the weight of the car significantly!
#9674
#9675
so RC MARKEY when are u goin to have the
18t center pullys and belts from Hot Bodies for the cyclone in stock
