Hot Bodies Cyclone
in half?
Yes.Middle bridge cut out.Works well in certain track conditions.
Yup, I tend to use the cut rear plate when the grip is really low. It just makes the car feel a little more stable.
ever try the plastic one off the sport?My track has low grip asphalt-Hate to start hacking up things with parts starting to be a problem here on the east coast.
BTW,Korey,great run at REEDY. Interesting setup to say the least.I can see how the slight but obviously effective changes to your setup from the norm would help free the car up to make the Jaco's work as well as they did for you.I am gonna try some stuff now that you have done so.Again,great job.
(i heard you did a 17.0 on friday.. but FAILED to show up on sat)
btw.. good to see you again and the rest of the norcal crew.
i failed so bad in RCGT i renamed myself to Ling Hicks.
Yeah, and everyone around him did their duty and called him Ling/Hicks all weekend long....LMAO!
Registered User
More steering
Hi everyone, what front would you all recommend to get some more steering in my Cyclone,I run on a fairly tight track and I am using a supplied one-way at the moment and suffer from bad understeer,any help or advise would be appreciated,cheers.
P.S.....or maybe I need to control my trigger finger a little better...
-Korey
Timing was at the middle hole, motor temps were comming off at about 170 with 2 fans. Without the fans it was around 200 deg.... but that gearing felt the best overall so I did what I could to bring the temps down. The trinity rotors are really good, so even if you get them hot a few times, they can survive it.
-Korey
-Korey
Tough room in here! Yeah car was very good 1st run on Friday,tried a bunch of wacky stuff and by the end of the day,I was back to my original start point.FAIL.I go home that night,kind of burnt out for lack of sleep and never woke up the next day until I heard my phone ringing.I was late.FAIL.I should have hit up the HB guys earlier,but didnt.FAIL.Thanks Chris for the pep talk!
upper deck ?
Does anyone know when the new upper deck will be out ?
I bought a weight tray that slides under the battery, and I can't use it because
I can't fit weight tray and battery in at the same time... Oh my...
