Exoteck XR3'12
Old 05-30-2012, 06:38 PM
  #46
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Originally Posted by Magnet Top
I was the other Exotek XR3 '12 T3 conversion that made the 17.5 A main at the Reedy race. Aaron helped me with setup all week which was instrumental in me making the "show". Thanks again .
Jake D.
Hi Jake
Congrat's you make the A Main...
I ran mine at Fastrax and it is working very well...love the XR3
OVA is offline
Old 05-30-2012, 06:52 PM
  #47
Magnet Top's Avatar
Originally Posted by OVA
Hi Jake
Hey Franko,
Thanks , could have been better but ended up 6th overall, not too shabby considering there were nearly 50 entrants...
See you at Fastraxx Saturday !
Jake D.
Magnet Top is offline
Old 05-30-2012, 07:43 PM
  #48
defcone's Avatar
Trader Rating: 15 (100%+)
Hey Franko,
Jake D.
What difference did you notice going to this chassis when compared to the kit one?
defcone is offline
Old 05-30-2012, 08:06 PM
  #49
Magnet Top's Avatar
Unfortunately I purchased the X-ray '12 just two weekends before the race, then put the extotek kit on just days before the Reedy race, so I didn't have the time to test back to back. I can tell you the exotek is more flexible than the standard chassis since it is both thinner and significantly narrow , which allows you to run lower ride height and not rub. . I ran the optional thinner X-ray 1.6mm top deck to make it even more flexible. I didn't get a chance to explore going back to the standard top deck.
Old 05-30-2012, 08:16 PM
  #50
OVA
OVA's Avatar
Hey Jake
I ran my XR3 with the stock Exotek top deck and I didn't like the way the car drive.it was a little too much flex for my taste ..So I put on the stock Xray 2011 top deck and it made the car react much quicker into the corner...maybe alittle more steering as well..
OVA is offline
Old 05-31-2012, 03:48 AM
  #51
R/C Tech Elite Member
Jamison R's Avatar
Trader Rating: 66 (100%+)
Originally Posted by AARON YOUNG
There was actually two exotek xrays in the 17.5 a main .Car was really good all weekend and consistent but good luck wasnt on my side.
Was there any standard T3 2012's in the A main? Is this upgrade worth the $. I like the suspension blocks. They look very solid.
Jamison R is offline
Old 05-31-2012, 09:27 AM
  #52
MikeR's Avatar
Great work guys! If you have any pics you could share from the race please forward to me so that I can post it in the news section.
MikeR is offline
Old 05-31-2012, 09:59 AM
  #53
Trader Rating: 38 (100%+)
I can't see why it wouldn't but just to verify... Does the xray center servo mount work with the chassis?
Also any issues with the narrow chassis and getting L/R balance? I generally have to move my electronics far to the outside edge to get my cars to balance.
or8ital is offline
Old 06-01-2012, 11:06 AM
  #54
OVA
OVA's Avatar
Hey Mike
I decided to put back on the Exotek top deck instead the stock Xray top deck and the Exoteck top deck really works on low grip traction
it does stable the rear end much better..
OVA is offline
Old 06-01-2012, 10:30 PM
  #55
Default Balance
There is no problem balancing the car . The servo is the light corner and I use pine wood derby tungsten plates they are almost the same size as the base of the servo . I also moved my speedo against the plates to shift the 60 grams forward .
AARON YOUNG is offline
Old 06-08-2012, 12:26 PM
  #56
yokemad's Avatar
@AAron
Hows things going on with exotek chassis?
Is there any chance to share your carpet setup
Many Thanx
yokemad is offline
Old 06-08-2012, 03:37 PM
  #57
Default Carpet
I haven't had a chance to run it on carpet since there's no carpet tracks in northern ca anymore. I will be running it at Vegas but that's a ways away . I will get my setup from the reedy on a PDF and post it soon as I can
Old 06-08-2012, 06:08 PM
  #58
yokemad's Avatar
Cheers Mate
yokemad is offline
Old 06-23-2012, 05:45 AM
  #59
I ran this setup last night on carpet, it was very different than my old Exotek '11 version, which I broke running mod..
I was running blinky mode 17.5
Running Jaco blue tires on a high traction track
I had some traction rolling issues running 2deg rear toe, neg 2 camber all around, ran both front and rear RC with 1.5 mm spacers, 50wt oil, 3.4 front spring, heavy sway bar and 1mm spacers in wheel at the front!!
Could it be this car just has too much flex?
Anyone have any suggestions?
I finished 3rd one sec behind 2nd place, top 3 cars on the same lap
Grant
lifeguy is offline
Old 06-25-2012, 08:09 PM
  #60
Dusttt's Avatar
Trader Rating: 144 (100%+)
I have the conversion on my car. What is the best combo of all the holders front and rear for say West Coast and how about parking lot?
Dusttt is online now
