Kyosho v-one rrr
#1517
Re: usa distributor?
Originally posted by CHUCKMANDO
I want to get the car, but with no parts availablity in the usa,kind of a tough decision.
Cheers
#1518
Re: tnx guys
Originally posted by bulletdays
The performance is ok, its just that the idle becomes higher after 3-5 laps of running.
Ok il try to see if theres a leak in my tank.
but do you think the tuning is ok?
#1519
How much would you guys pay (USD) for a V ONE RRR WC Team Edition?
#1520
Ive tried to put the tank and the fuel line under the water and blow some air into the tank, while pinching the other line so no air can come out. but there are no leaks in my tank.
I think better check the tuning....
#1521
#1522
rrr wc
for people who own rrr wc edition, can tell us if the following is included in the kit
1) alu wheel hex
2) front and rear universals
1) alu wheel hex
#1523
Re: rrr wc
1) alu wheel hex
1) alu wheel hex
#1524
can any one confirm if I can use 5 pieces of AAA size battery for RRR and how?
Thanks,
Thanks,
#1525
hi guys!! , i just have a quik ? , does anybody have a method or know any compatible side belt for the rrr?? , mine is kind of streched and it's not that old!!
#1526
Super Moderator
Re: ..
as far as the belt
ask that question to jeffreylin , he should be able to help you with that!
#1527
Re: ..
#1528
Re: ..
#1529
Roll center
Can somebody explain on which hinge pin plastic holder (the AA,BB thing) that will make the roll center lower? Pls give details on Front and Rear?
#1530
ROLL CENTER CLIPS
A: set on the lowest postition in the rear will lower your roll center.
B: set on the lowest postition in the rear is the next step up
B: on the reversed position would be next higher
A: on the high postion for the rear would be the highest setting.
(front)
the higher the inner hinge pin is the lower the roll center
(front)
