Team Associated TC4
#3706
Originally posted by jag88
This might be a better place to ask..... has anyone put a TC3 rack into the TC4 ? I understand that it's suppose to really help the car.
Thanks.
Thanks.
#3707
the tc3 rack gets bound up easily but does add more ackerman than the tc4 rack.the tc4 rack is a little different than the nitro rack.you need to shim the ball studs to fix this due to the steering rack placement.i offer the ability to use both steering racks on my chassis kit but i changed the location of the tc4 steering rack to be able to make more ackerman adjustments.
#3708
Thanks.
Thanks.
#3709
Jason, when you add shims on the TC4 rack does it give more steering around center or more at the end ?
Thanks.
#3710
Could someone please e-mail me a TC 4 blank setup sheet as I am also having trouble with the ae site.
[email protected]
Thanks guys
[email protected]
Thanks guys
#3711
generally adding ackerman will smoothe the steering going in to the corner and make it more aggressive coming out.when you get it set just right the car will rotate extrmely well without any tire scrub.it may feel aggressive but will carry the most speed through the corner.
#3712
[email protected]
Thanks guys
[email protected]
Thanks guys
are you trying to edit the setup sheet? because if you have acrobat reader it won't let you edit it and save.
#3713
Thanks Jason.
I have your Xray chassis and just purchased your TC4 chassis. Now I'm waiting on your 05 Xray chassis.
You make good stuff.
#3714
What do I need to get to run these outdrives.
#3715
TC3 Rack for the TC4
Can not imagine why we or anyone would want to try the TC3 rack. We went well out of our way to use the NTC3 rack in the TC3. So why would you want to put the TC3 rack in the TC4.
The steering rack in the TC4 lets you adjust your ackerman quite a bit already.
So why are people trying this?
Later,
Later,
#3716
#3718
-Dave
#3719
so the delrin outdrives aren't actually any good? i was going to get some to replace my heavy AE steel ones (and their lightnened ones but still weigh a tonne )
so i take it them speedway PAL outdrives are on there way?
#3720
-Dave
