Serpent S411
#3901
Any Serpents going to the IIC?
#3904
Thats a great question......as I look at several of the posted setups for asphalt, just about all of them run the hard arms, yet they will use the thin chassis and even go to the extent of cutting the suspension blocks in half to get more flex...........so why not run the standard or even the super soft arms?
OR would these be used for a super high traction track?
#3905
Just wondering if you've ever found any designation on the rear uprights, c-hubs or steering blocks that say "H" for hard....I've never found any, so I'm asking. Arms are marked no problem. I know that they hide the "L"eft and "R"ight on the steering blocks quite well and they don't jump out at you, so just wondering about the "H".
#3906
Agreed to the first statement.
#3907
#3908
S411 Technical layout
FYI attached is a set up tried on a very technical layout at one of our local tracks, Bitten near Mornington, Victoria, Australia.
Enjoy. I found this to suit my driving ability, being sub par, i was able to throw this around quite easy with no nervous tendencies.
Main change was the use of the new EXOTEK S411 Soft chassis with a S411 standard top deck. Lots of grip.
Cheers Ren
http://www.rabhobbies.com.au/PDF/S411SETUPBITTERN.pdf
Cheers Ren
#3909
SERPENT S411/Sport/LE/TE Battery Strap Velcro
#3910
HiH
Ed
#3912
Had a run with my S411 for the first time the other day and first impressions are awesome, dropped at least half a second a lap from my previous times with my T3 12 , and this was with old old tyres on a very loose and dusty track, and from myself who hasn't driven a touring car in over a month , I was running basically Try Hard's ( Ed ) setup from Landsborough as our track is similar, and it worked well for me , but I am running std kit arms not the hard ones and the v1 shocks , is it worthwhile changing to the V2 shocks? Also what are people's opinions on the Exotec chassis as I am looking a grabbing it .
#3913
We now have two racers on the Exotec chassis and both seem to think its worth the investment, seems to help plant the rear a little better.
Thanks for checking the "H" parts out, guess I'm going to have to get a magnifying glass out, or perhaps the older hard parts weren't marked? In any matter thanks again.
#3914
How does the exotek compare to the serpent 2mm?
#3915
