Like Tree4Likes
Tamiya TRF417
Old 01-10-2012, 09:19 PM
  #2551
hotdognobun's Avatar
Trader Rating: 32 (100%+)
Anyone have any issue with front belt rubbing servo mount on 417x?
hotdognobun is offline
Old 01-10-2012, 09:41 PM
  #2552
ShrewdRacer's Avatar
check where you mount your diff pulley. it should be on the far right side of the spool, your diff pulley should almost be touching the shocktowers when done correctly..
ShrewdRacer is offline
Old 01-10-2012, 11:01 PM
  #2553
i shimmed as much as i could! these cars are so narrow nowadays
Old 01-11-2012, 04:39 AM
  #2554
but they are more precise these days too. i didn't shim mine more than what the manual says and it's all good
check your pulley, you could have screwed on the wrong side buddy.
Old 01-11-2012, 06:05 AM
  #2555
Guys, what spring feel almost the same to HPI silver or blue? It's hard to find HPI parts in my place. The available brands are xray, photon, and tamiya.
Wilson Picaldy is offline
Old 01-11-2012, 06:13 AM
  #2556
OI82lose's Avatar
Get the TRF spring from speedtech. They work great!
http://www.speedtechrc.com/store/ebpage.asp?page=home
OI82lose is offline
Old 01-11-2012, 06:46 AM
  #2557
FunkyDunky's Avatar
As mentioned you shouldn't need to over shim, double check that you have fit the pulley on the correct side of the spool, its very easy to miss fit
FunkyDunky is offline
Old 01-11-2012, 07:35 AM
  #2558
2-Bad's Avatar
Trader Rating: 24 (100%+)
Nobody runs Tamiya springs competitively unless the rules dictate you have too. Get the Xray...
Theorical Rating
HPI Blue = 14.8lb
HPI Silver = 16.8lb
Xray 2.6 = 14.6lb
Xray 2.8 = 15.8lb
Xray 3.0 = 16.9lb
2-Bad is offline
Old 01-11-2012, 09:06 AM
  #2559
Theorical Rating
HPI Blue = 14.8lb
HPI Silver = 16.8lb
Xray 2.6 = 14.6lb
Xray 2.8 = 15.8lb
Xray 3.0 = 16.9lb
I use them all the time. The latest and greatest isn't always the best.
Juan Aveytia is offline
Old 01-11-2012, 09:32 AM
  #2560
MikeR's Avatar
Trader Rating: 15 (100%+)
It's doesnt need shimming- you need to rebuild the spool! The pulley is backwards.
MikeR is offline
Old 01-11-2012, 09:40 AM
  #2561
Pro10noob's Avatar
Trader Rating: 13 (100%+)
@hotdognobun....It should be like this
regards Roy
Pro10noob is offline
Old 01-11-2012, 10:09 AM
  #2562
Bigz84's Avatar
Default shocks
hello,
i have a question. what does the part number 42102 come w/, piston wise? 2 hole-3 hole? i'm running a competitors car, but HATE the shocks that are on it. i read that the bodies are threaded, but i have seen pictures that there are ride height spacers w/ the kit, or it looks like ride height spacers??
also, i'm assuming that the 42102 is the shocks that come w/ the 417. is that correct?
any info would be greatly appreciated
Bigz84 is offline
Old 01-11-2012, 10:28 AM
  #2563
Racing4Evo's Avatar
Originally Posted by banquer
Hello guys!
First of all, Merry Christmast to everyone!
Past days, I finished mounting my 417X, and I'd found one problem.
The front belt, touch the inner aluminium servo mount and antenna post.
I'd shaved the inner servo mount to resolv the problem (about 1,5-2,0 mm).
I review all the mount points about central spur gear, rear diff and front spool without founding any mistakes, and shimmed them in the right possition like manual drive us.
And also, the upper belt tensor, is to centered and I must do a drill 1.5 mm to left about not touch the front belt.
Look at this photos.
Do you have this problem? Any ideas?
King regards from Spain!
Originally Posted by Racing4Evo
You mounted the front pulley on the wrong side of the spool assembly. Look at this picture from kentech's blog. His is mounted all the way against the right side bulkhead.
Someone had this problem a couple pages back....
Racing4Evo is offline
Old 01-11-2012, 11:18 AM
  #2564
regards Roy
thanks for picture i am using gear diff front and back. The picture of kentech does show that belt is away from mounts but once is starts rotating the belt will move left/right and will at one point touch servo mount and even belt tensioner! I went the Yokomo route and mounted my servo with servo tape and further out! Always a way
Old 01-11-2012, 01:26 PM
  #2565
Default 417x
heres some old build pictures of my 417x
Attached Thumbnails Tamiya TRF417-dscn1123.jpg   Tamiya TRF417-dscn1122.jpg   Tamiya TRF417-dscn1121.jpg
