Tamiya TRF417
#2702
I'll run my 414 if they allow me to keep my 416 steering rack on it. What wing is everyone using now for nsx bodies? But, I really don't think tamiya will bend the rules. I just bought an Evo5.
#2703
In English
[TRF] 44mm Double Cardan Joint Shaft (2pcs.)
[TRF] Drive Shaft for 44mm Double Cardan Joint Shaft (2pcs.)
[TRF] Axle Shaft for Double Cardan Joint Shaft (2pcs.)
[TRF] Joint Casing for Double Cardan Joint Shaft (2pcs.)
[TRF] 1050 Ball Bearing (3mm Thick, 2pcs.)
[TRF] Cross Joint for Double Cardan Joint Shaft
#2704
Does any company make 6 degree C hubs for the 416/417 (or another model that will cross over)?
#2706
#2709
Set-up
As far as wings, the high down force and the low down force were both being used last race, most are using the NSX but the 416 that TQ'd was using a Lambo body and Rod ran the new Audi body, Timmy my son ran the NSX. So take your pick! The Tamiya B3's are like always very track temp oriented so just as before, set-up can change from day to day! The spec tires can be on the edge when the weather is cold!
Just my 2$
#2710
not really as adding/removing shims under the blocks changes both kickup/dive and caster.
#2711
You would probably have to get a clarification on the steering rack from Fred but I wouldn't see why not, it's all Tamiya parts!
Just my 2$
Just my 2$
#2714
Zero Force Tamyia TRF417 Bearing Set (12 pcs)
#2715
Anybody know if trf416 parts are compatible with the trf417x?
