TAMIYA M-06 Thread
#1578
I love it! Battle worn cars are the best. My tt-01 last year Ferrari body is scarred, too. It could last another few races, but I chose a light weight Audi R8 LMS body because it has better aerodynamics and is lighter. I don't build them for the shelf!
Question; how do you adjust the camber arms on your car? I cannot get a tool in there, I need to pop them off, adjust, and pop back on. Not what I imagined putting on the turn buckle set.
Cheers,
Hugo
Cheers,
Hugo
#1579
I use a set up station so I adjust them on the car. I also use a 4 mm wrench I bought from Sears.
Fronts: I remove the body posts which makes it easy.
Rears: are a PITA . The 4mm wrench I use is a bit angled, so I switch back and forth to make 1/4 turn adjustments. Sometimes I need to compress the suspension to get the tip of wrench on turn buckle. A true exercise in futility!
#1580
maybe a stupid question but I'm so far unable to find opinions related to this.
I want to get an M chassis, but I don't know whether to go for the M05 or the M06.
(This will be my first on-road car, so far I've only driven off-road 4x4)
I've been checking out the M05 Pro V2 which I can get for 169 euro (around $214), which looks pretty good.
What are the reasons one would pick the M05 over the M06 or vice versa - I get it's FWD vs RWD, but what are the implications ?
And is there more to it than that ?
#1581
Most people find the M05 easier to drive.
#1582
#1585
The M06 you need to be in tune with the car. End result, it will make you a better driver.
#1586
(the M06 motor is over the tires = better grip)
M05 is easier to setup than M06.
Real 1 to 1 scale car racers like the feel of a RWD car.
I have all the mini's except the M05. When I won a M05 I traded it in for a M06. At the time I did not like the M05 construction. With the M05 v2 they changed some of those things that I did not like. Really it is personal preference.
#1587
Hugo
#1588
+1. The whole Dutch Tamiya Cup M-Chassis class is made up of M5 and M3 cars, so I got a 6. Just to be weird. Which comes natural to me anyway. I just got the car on the road at 23.00h yesterday, copying Raman's set-up, so I cannot judge the handling yet. I did notice braking is not a good idea...
Hugo
Hugo
#1589
Hugo
Hugo
Where do you put your car on the track ?
#1590
@Raman; just outside on the wet brick road. Not the preferred surface, I know, but still it accellerates like mad. Tire prep of any sort is not allowed in the Cup I race.
@Pygmy; I will race all venues of the Tamiya Cup, I have no home track. I hope to do some testing at the Lelystad outdoor track, and the Vianen indoor track. That indoor track will be the only indoor coming season, the first race of the Cup.
Hugo
Hugo
