TAMIYA M-06 Thread >
TAMIYA M-06 Thread
Like Tree120Likes
TAMIYA M-06 Thread
Old 05-25-2012, 03:18 PM
  #826
Raman's Avatar
Trader Rating: 94 (100%+)
Default Fiat Abarth 1000 TCR on M06
Here is the Fiat Abarth 1000 TCR on M06 chassis. Note this is without any cutting or modifications to body.
Back sits a little high. If you remove dummy engine and open up engine bay floor, the body will fit correctly.
Raman is offline
Old 05-25-2012, 05:18 PM
  #827
spring71's Avatar
Smile
Tamiya M06 spare and hopups are available at TQ.
http://www.tqrcracing.com/shop/parts...arts_p_id=1866
Here is the Mini A Main video, TCS at TQ RC RACING.
+ YouTube Video
Thanks.
spring71 is offline
Old 05-25-2012, 05:23 PM
  #828
Morbo's Avatar
Anyone ever try spam musubi? It's delicious!
Morbo is offline
Old 05-27-2012, 11:51 AM
  #829
Raman's Avatar
i have these yeah racing front knuckles for trade. Let me know if you are interested
http://www.rctech.net/forum/r-c-item...ah-racing.html
Raman is offline
Old 07-04-2012, 12:22 PM
  #830
Raman's Avatar
I run a Ballistic 21.5 in mine. I noticed gear mesh is a bit sensitive.. depending on which screw i tighten first
So i figured best to pick up the Aluminium motor mount. Problem is still the same. If don't use the gear cover, the mesh is fine.. so gear cover seems to be distorting things.
Also, the gear box plate will not work with a Ballistic.. the motor tabs will come into contact with aluminium. So you would either have to cut the ballistic tabs or mill out a notch in the aluminium, which would ruin nice blue anodised look
Raman is offline
Old 07-06-2012, 04:48 PM
  #831
Capt'N_Slow's Avatar
Are their any TCS setups posted for carpet for the m06?
I have found some setup sheets in Japanese on the tamiya.com website but can not determine if they are for outdoor or indoor use.
Capt'N_Slow is offline
Old 07-16-2012, 07:03 PM
  #832
idrummerboy13's Avatar
Trader Rating: 15 (100%+)
Default new to tamiya
Tomorrow I will be getting my alfa romeo m06. Really excited I usually race 2wd buggy but I am getting this for fun plus it would look good on a shelf..
I have a savox servo, sphere esc and novak 10.5 I can throw in...
Any gearing suggestions?
idrummerboy13 is offline
Old 07-16-2012, 09:03 PM
  #833
Raman's Avatar
I personally would not go over a 13.5 in this car. I run mine with either a 21.5 or 17.5
Gearing, you are limited.. highest pinion is a 20T. So no worries on over gearing it.
You will definitely need to pick up a set of oil filled dampers either plastic or TRF.. The stock dampers in the M06 kit will not handle for anything.
Raman is offline
Old 07-17-2012, 05:05 PM
  #834
I am prob ganna grab a cheap 13.5 novak core.. your right, 10.5 is just fast.
Old 07-18-2012, 04:54 PM
  #835
Hyde's Avatar
I want an m06 so bad!
Hyde is offline
Old 07-24-2012, 10:36 AM
  #836
Hello everyone. I just purchased an M06 and I am trying to make it scaler look on a BMW 2002 turbo body. I would like to know where to get these rims for the M06.
http://world-viewer.com/photos/bmw-2002-turbo/09/
They are gold with polished lip.
Thank you
DBFIU is offline
Old 07-24-2012, 02:48 PM
  #837
Raman's Avatar
Thank you
Your best bet would be these:
http://www.abchobbyusa.com/110mwheels-meshwhite.aspx
You will have to paint them gold and chrome the silver
Another option is:
https://www.tamiyausa.com/product/it...oduct-id=53468
But these are 1/10 scale, not M chassis, so you're ride height will be off.
Raman is offline
Old 07-24-2012, 04:14 PM
  #838
Another option is:
Excuse my ignorance, I noticed most of the wheels/tires come as a combo where the tires are already mounted. can you point me in the right direction for mounting tires and which tires to get? The first link are just rims. Thanks
DBFIU is offline
Old 07-24-2012, 04:26 PM
  #839
Raman's Avatar
Here are the options from abc USA
http://www.abchobbyusa.com/tiresandwheels.aspx
I ran the N Racing slicks .. They're very good.
Raman is offline
Old 07-25-2012, 07:04 AM
  #840
I appreciate your help! Do those tires need to be glued to the rim with CA glue? Sorry for the stupid questions, I own a stampede 4x4 so that's what I'm used to doing on my off-road truck.
DBFIU is offline
