Losi XXX-S
#7711
R/C Tech Elite Member
Re: Steering Hub Bearings and Carpet fuzz problem
Originally posted by TakDrift
Anybody have problems with carpet fuzz getting into the steering hub bearings? Any tips on avoiding or eliminating the carpet fuzz from getting into the bearings? Thanks.
#7712
Randman, is the Acer bearings metal shielded or teflon shielded? Thanks.
#7714
Originally posted by Randman
They have a special shield that I have no idea how to spell, it's almost like a perfect molded plastic shield, really good tolerances...
#7715
Re: Re: Steering Hub Bearings and Carpet fuzz problem
Get some Acer sealed bearings, that should keep the fuzz out pretty well... Or just spray them out with motor spray often, and dont use oil...
are you mad.
the bearing needs some oil and i use the actull oil they use.
#7716
Re: Re: Re: Steering Hub Bearings and Carpet fuzz problem
Originally posted by trf racer
are you mad.
are you mad.
#7718
KEVIN K:
if i use the 2r in front... aside from removing material from the front bumper, (where you put the droop screw) do i also have to take out material from elsewhere in the bumper?
i notice that the hinge pins might hit the area where you screw in the bumper and the chassis...
jason
jason
#7719
Trader Rating: 32 (100%+)
Highway....No I did not have to remove any more material from the bumper...when I cut the droop screws off I just cut the bumper straight where it goes out for the droop screws...do you follow what Im saying? I sill use the screw holes to hold the bumper in place on the chassis....there is no clearance problems there. Hope this helps.
#7720
I just did this mod on my car and it is very simple, just cut the tab off that houses the set screw for droop...
KevinK,
Have you ran the metal outdrives? If so what did it do for you?
Thanks,
Kevin
KevinK,
Thanks,
Kevin
#7721
KEVIN K:
thanks... helps a lot.
#7722
cool. thanks...
when you did this mod... how was it?
#7723
wannabe....I have run them in the front with rubber tires but have yet to really try them with Foam tires....maybe this weekend or next. Once I do I will let you know how it works out. With rubber tires it gave more on power steering so I would think it would do the same but Im not sure that I need that with foams, but its worth a try.
#7724
Yea I might try it this weekend...Thanks for the reply...
Kevin
Kevin
#7725
BTW: I am running rubbers now.....
