Losi XXX-S
#5686
is your droop more that 5mm?, are those the purple springs the front ones? if so there shorter than the silver rears it think.
#5687
dstrout, Try taking your rear droop screws completely out, then set your ride height. With RH set, put the droop screws back in, and set your droop. Note: The spring should never be preloaded. With the car off the ground, the spring should move freely (it can be close, or touch a little, but shouldn't be compressed)
Also, it's hard to tell in the picture, but it looks like you have the MF low roll center blocks. If you do, make sure your rear pivot support is in the lower hole. If it's in the upper holes (if that'll even work???) it would probably make it impossible to get ride height.
alfa, I don't think the spring length should matter. I run the 1" springs (shorter ones, long are 1.15" I beleive) front and rear, and get ride height easily. As long as you've got the same spring length left and right, it shouldn't matter.
#5688
I've had the same problem with certain set ups. The G+ springs are all 1" - I think the old kits were 1" up front 1.5" in the rear. If you have any Associated clip-on pre-load spacers it's a good temporary fix. I finally found some 1.15" springs for the rear end and it orks much better ( with the associated clips the spring rub on the shock bodies ).
#5690
Originally posted by STLNLST
is there a chance that you have the short FRONT shock shafts in the rear???
I'll check it out. I know my front shocks are 2.3", as I measured them to make sure they were the same when I pout them back, but I haven't measures the rear -- I'll check it out. I'll also check the spring length, as I have a whole box o' springs and may have grabbed the wrong ones.
thanks guys,
dave.
#5691
Doh!
Well, I guess this falls in the category of having "a keen grasp of the obvious". A droop gauge is not a ride height gauge
I was trying to get the car up to the "3" on the droop gauge, which is closer to 12.5 mm! It's no wonder I ran out of shock travel. I'll have to run out & buy a ride height gauge at lunch today.
Thanks for the spring-length tip, though -- I did have 1" springs on the back -- I put the longer ones on while I was at it.
thanks,
dave.
thanks,
dave.
#5692
HAve you guys checked out the pictures from the carpet nats. Heres my question and I havent yet seen it addressed in the thread.
Has anyone noticed the ft guys cahnging the link from the servo to the steering rack take a look they are placing a ball in te middle of the rack lengthing the link. hhhmmm why would they do this?
any insight
later
any insight
later
#5693
i have the g+ and i run on a tight track (with my steering maxed) and i can't get the thing to turn (it pushes BAD!) ii run the orage springs in the front and whites in the back it also likes to lift the tires up in the end of the straightaway going into a 180 has anybody else had this problem i have tried lots of different stuff and it only makes it a little better! can anyone help?
#5694
any insight
later
any insight
later
#5695
any insight
later
any insight
later
#5696
#5699
High Roll for slick surface.
I am not either of the guys you mentioned, but I would run high roll center on a slick surface because it has been my hands on experience that the higher the roll-the more planted the tires become-hence the more mechoncal grip you produce. After running both front and rear high, you can slowly lower the end that feels too planted-no matter what springs, tires etc you use.
Its a subtle thing to feel. Roll centers arent the easiest thing to feel till youve actually changed it and nothing else and know what it does on your car.
