Like Tree2Likes
Losi XXX-S
Old 03-14-2003, 09:41 PM
  #5701
NeO-pRo-3's Avatar
i got a question, which Titanium-turnbuckles would be better? THe Lunsford ones or the Team associated FACTORY team ones for the lOSi. I like the AE ones cuz they blue, but i don't know if they are better then LUnsford ones. HEre's the link, on ebay,
http://cgi.ebay.com/ws/eBayISAPI.dll...&category=2565
NeO-pRo-3 is offline
Old 03-14-2003, 11:35 PM
  #5702
Brian McGreevy's Avatar
Lunsford...beefier.
Brian McGreevy is offline
Old 03-15-2003, 09:51 AM
  #5703
STLNLST's Avatar
Trader Rating: 32 (100%+)
I have the lunsford one's on all of my cars but that's not to say that the AE one's are crap. From the begining of my RC racing I always went with lunsford so that's what I stuck with. Never had any problems with them so I've kept the tradition going.
STLNLST is offline
Old 03-15-2003, 10:17 AM
  #5704
Oasis's Avatar
Trader Rating: 38 (100%+)
I to have allways used Lunsford,never had any problems with them.I dont think their is any problems with the Assoicated but I still like the look of the Lunsford and the problem with the blue scratching off on the Associated when you adjust them has kept me from paying for a set(if they come with the car.. cool,but I'm not paying for them).Hey STLNLST have you tried the contac paper yet?The new Losi Lexus IS300 looks good and it looks like it will work real good.
Oasis is offline
Old 03-15-2003, 10:37 AM
  #5705
NeO-pRo-3's Avatar
Thanks Guys
Old 03-15-2003, 12:54 PM
  #5706
Blakesrc's Avatar
Trader Rating: 26 (100%+)
Default Balancing the XXXS
Any of you use a scale setup to balance your car? Is it best to use 4 scales to try to balance out the whole car or just 2 and do the front and rear separate?
Blake
Blakesrc is offline
Old 03-15-2003, 04:36 PM
  #5707
racecar850's Avatar
Exclamation BALANCING BLAKESRC CAR
To get the best results use 4 scales.
Have the car ready to run....no body.
Make sure the scales are on a FLAT & LEVEL (very important)surface
WALMART 3 pound postage scales 20$ each
racecar850 is offline
Old 03-15-2003, 08:33 PM
  #5708
KevanB's Avatar
Exclamation HEELP!
I have a xxx-s graphite, with a p2k2 and explorer2. The problem is that whenever I race with stick packs, they seem to fall out of the car on high speed corners. I have already tried to add some servo tape and foam tape on the bottom of the battery holder piece. I have also looked into the part that allows you to use screws instead of body clips to hold down the battery.
In my recent races I have had to resort to using strapping tape to strap in the battery so it would not fall out.
Do you guys have ANY ideas as of how hold down the battery wihtout using and replacing tape every heat of the race? It is becoming very annoying.
ANY help would be appreciated.
KevanB is offline
Old 03-15-2003, 08:41 PM
  #5709
http://www2.towerhobbies.com/cgi-bin...?&I=LX2780&P=7
get a set of these, drill and countersink a hole just to the outside of the battery in the center, bolt them down..... this will keep your stick pack in.... I had to do it on my brothers XXX-S... works well and is cheap...........
IMPACTPLAYR is offline
Old 03-15-2003, 08:45 PM
  #5710
Thumbs up batteries
KevanB,
The best way I found was to cut velcro to fit the contours of the battery hold down. Then put the other velcro on the batteries themselves of course lining up both pieces so they stick together get the good velcro, never had one come out that way.
Rod
rkeasler2 is offline
Old 03-15-2003, 10:40 PM
  #5711
NeO-pRo-3's Avatar
i have the same setup, but my stick packs and side by side packs still dont fall out!
Old 03-16-2003, 06:19 AM
  #5712
Rookie01's Avatar
Default question
Someone know if there any aluminum outdrive available?
Rookie01 is offline
Old 03-16-2003, 06:30 AM
  #5713
KevanB's Avatar
I dont quite understand how to use the associated serco mounts. And I doubt that the velcro would help enough. BTW this is a used car, so it could just be the wear and tear that makes the batteries fall out.
I may have to resort to rebuilding my stick packs because I have NEVER had a side by side fall out!
KevanB is offline
Old 03-16-2003, 06:56 AM
  #5714
no our cars had a problem from the get go.....
Heer's a pic for ya.....
I forget that on message boards we need pics to replace common since......lol J/K
Old 03-16-2003, 08:00 AM
  #5715
sorry forgot the pic
