MUGEN SEIKI MRX5 >
MUGEN SEIKI MRX5
Like Tree3Likes
MUGEN SEIKI MRX5
Old 03-15-2014, 06:00 AM
  #2761
Arahawak's Avatar
Trader Rating: 32 (100%+)
Originally Posted by motojon
the front bulk heads are longer to accommodate the new wire bar mount and so the body post mount is also different
Looks longer but it's the same, just moulded to fit in the wired roll bar.
Arahawak is offline
Old 03-15-2014, 02:57 PM
  #2762
Roelof's Avatar
OK, did get the old MRX5 kit for the spares and did take a look at the differences.
With my mspaint skils I made some drawings and 2 ideas how to use the old bulkheads with a WC edition upper bulkhead.
The 1st is just to drill a hole in the upper bulkhead, the seccond is an adapter to make the extension.
Roelof is offline
Old 03-16-2014, 12:09 AM
  #2763
Arahawak's Avatar
The former looks more sound!
Arahawak is offline
Old 03-16-2014, 08:24 AM
  #2764
Trader Rating: 13 (100%+)
I have a brand new mrx5 WC kit in the box. $550 obo
1966ss is online now
Old 03-26-2014, 03:47 AM
  #2765
Kanea6's Avatar
Trader Rating: 7 (89%+)
Have any of you had any problems with the fuel tanks lately? I've bought 3 brand new ones and not one of them would seal correctly, I'm not too sure if it's the seam that's leaking or the lid? I keep having fuel all over my car after a run and every time it was refuelled it was done very carefully not to spill any so we can see what's happening, I've replaced all the fuel line etc but after 3 brand new tanks I finally have a tank that's not leaking. Anyone else having this problem????????
Kanea6 is offline
Old 03-30-2014, 06:49 AM
  #2766
MugenDrew's Avatar
Trader Rating: 36 (100%+)
I have never had a single issue with a Mugen tank. However here are some tips for keeping a prefect seal at the tank neck. When not in use either remove the o-ring from the lid or place a piece of a zip tie between the tank neck and lid. This will allow the tank neck to shrink down and the o-ring to expand. Whenever fueling always allow the tank lid springs to slam the lid closed.
Normally if you have a leak at the seam with a full tank the car will become most when sitting and if you run it the car will shut off/stop running a little bit past the half way point.
With the five be sure you have not mounted the receiver battery to far towards the rear (bins against the tank) or to far forward (leads or battery will make contract with front belt drive pulley).
MugenDrew is offline
Old 04-02-2014, 02:36 AM
  #2767
Kanea6's Avatar
Ok thanks, now I have another question, by moving the front upper arms up or down what does it do to the car? Does it give the car more initial steer by moving it down or what???
Kanea6 is offline
Old 04-02-2014, 07:07 AM
  #2768
asw7576's Avatar
The height position of upper arms link has something to do with front roll center .... ie. Front section body roll behavior.
If u increase the height position of upper arms on the outside ( adding shims on the steering wheel kingpin ) your car will be more responsive for chicanes , left - right - left slow corners. Technically the front of your car has higher roll center setup.... meaning : the front section is harder to experience body roll. My suggestions : follow the factory setup manual given by mugen seiki as your starting point.
Please download xray nt1 setup and read front and rear roll center topics.
asw7576 is offline
Old 04-02-2014, 12:43 PM
  #2769
ralphierace13's Avatar
when u raise the inside of the upper front arms u are lowering roll center I find with them in the up position car pushes more so I leave them down and that's raising roll center lets its roll more = more traction
ralphierace13 is offline
Old 04-02-2014, 01:52 PM
  #2770
lil-bump's Avatar
Trader Rating: 89 (100%+)
Somewhat correct... Raising the inside pivot point of the front upper A-arms does lower the front roll center. But a higher roll center = Less roll = Less steering. Whenever the roll center is raised or moved closer to the Center of Gravity the car will roll less..
Pass you soon...
lil-bump is offline
Old 04-02-2014, 04:12 PM
  #2771
Roelof's Avatar
Just change it and feel the difference.....
Roelof is offline
Old 04-02-2014, 11:12 PM
  #2772
Kanea6's Avatar
ok no worries thanks everyone, im just at the pointy end where im just trying to find like .1-.2 of a second and just thinking of areas where i think the car may be lacking a little thanks
Kanea6 is offline
Old 04-03-2014, 02:01 AM
  #2773
Aza088's Avatar
I know how you can find .5 of a Second!!!!
Aza088 is offline
Old 04-06-2014, 09:31 PM
  #2774
SMcpot's Avatar
Trader Rating: 22 (100%+)
Congrats to L. Collari on his ENS victory!
SMcpot is offline
Old 04-06-2014, 10:49 PM
  #2775
Snowy's Avatar
Trader Rating: 15 (100%+)
And Robert for his TQ and second place. Mugen 1 and 2!!!
The MRX5 has still got it Aza.
Snowy is offline
