Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 07-12-2005, 10:00 AM
  #10306
IslandBwoy's Avatar
Fowl play!!!!!!!!!
Just remember; Tony told me about about troy's holes so if you have questions you have to ask him. That is all i was saying :-) LOL
R.
IslandBwoy is offline
Old 07-12-2005, 12:40 PM
  #10307
helo again, got the trf shocks on ther way, can some one send me a set up 4 a stock standed car but with trfs on? im in the uk on tarmack runing 19t spec if it helps, just wanted a set up as a starting point with them. if u have got it on a schumacher set up sheet could i have that as i understand them better lol but if not it dnt mater,
my email is [email protected]
bob33 is offline
Old 07-12-2005, 01:05 PM
  #10308
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I don't think the TRF shocks can get long enough to use with the stock shock towers. You'll need to get the lowered towers to use them I think. Someone correct me if I'm wrong.
Jon Kerr is offline
Old 07-12-2005, 01:41 PM
  #10309
AdrianM's Avatar
I think they will work if you use the long shock tops.
AdrianM is offline
Old 07-12-2005, 01:53 PM
  #10310
The Evicerator
BOOYA YOU'VE BEEN SERVED!
Steve Weiss is offline
Old 07-12-2005, 02:15 PM
  #10311
TRF shocks can be used with std towers. You just need to use the normal Schumacher bottom ball joint, and build them to std shock length. From memory this needs to be 64 front, 67 rear. I could be wrong on that though.
If you look on the schumacher site, i am fairly sure that any of our "UK" setups will be with TRF shocks, and AE springs. Towers will probably be the low ones, but i guess this is usually stated. If they are low towers, use the same rear location as the sheet says, but use the middle hole on the front (short towers have different top mounting points). If they are Teemu towers, then you can use the same hole as the sheet says.
Hope at least some of that makes sense!!
MattW is offline
Old 07-12-2005, 02:26 PM
  #10312
AdrianM's Avatar
DOH!
AdrianM is offline
Old 07-12-2005, 02:35 PM
  #10313
yep alot of that makes sense thanks, im geting the teemu low mounts anyway. thanks 4 the setup Adrian i will giv it ago but will have to make it a bit higher ride hight as our track is a bit bummpy lol. thanks all. bob
bob33 is offline
Old 07-12-2005, 02:44 PM
  #10314
Jon Kerr's Avatar
That's right, I suck!
Jon Kerr is offline
Old 07-13-2005, 12:07 AM
  #10315
bender's Avatar
Speaking of Tamiya shocks, I just got my set today
I noticed that the instructions tell you to place an o-ring between the piston and shock body to limit the shafts travel. Is this how everyones is running theirs? Or can i just leave them out?
bender is offline
Old 07-13-2005, 06:16 AM
  #10316
PW
PW's Avatar
Just leave the o-ring out
PW is offline
Old 07-13-2005, 08:07 AM
  #10317
belgianchamp's Avatar
Hi PW,
I have them in, is it better to leave them out?For droop or something?
belgianchamp is offline
Old 07-13-2005, 08:32 AM
  #10318
PW
PW's Avatar
Originally Posted by belgianchamp
Hi PW,
Well it depends on the length of the shock bottom. I leave the o-ring out and use a shortened Schumacher ball-cup so I can use a wide range of spring lengths
PW is offline
Old 07-13-2005, 12:27 PM
  #10319
bender's Avatar
Ok, I left the o-rings out and with the standard tamiya shock end I've got a length of 62mm - with an extra couple of mm to play with.
Wow, are these shocks smooth, and so easy to build
bender is offline
Old 07-13-2005, 05:53 PM
  #10320
P-DUB's Avatar
Sounds great, make sure your rear shocks are at least 1mm longer than the fronts
P-DUB is offline
