Schumacher Corner
#1981
Trader Rating: 32 (100%+)
RcRaptor.....for Oval you probably want to run a stiffer right front spring and run the same spring on the left front and right rear and then a little softer of the left rear. That would be how I would start. I ran a Tamiya 03 on the Oval for a whole summer and thats how most of us set the cars up spring wise. We also ran a harder right front tire as well. The One-way should be good for the Oval. On a road course the One-way is faster most of the time unless you are on Foam tires. I hope this helps but this would be where I would start if I ran Oval with my Mission.
#1982
Hey all...
I got a SST Rally car coming from Les! and looks like I might be getting a Tekin ESC for it from the buy/sell/trade forum so I still need:
A reciever that works with Air/Sanwa on 75mhz and some spare SST parts...maybe a 'parts car' if the price is right. So if any of you have anything lying around.......
Another question, there is a guy in town here who had a Schumacher TC for sale...it was in pretty bad shape, but it was all there. The box, bunch of wheels and tires, some spare parts, etc. I might offer him $40 for it or something but I want to make sure it the 'same' as the SST Rally kit (its the Lancer Evo kit from racing-cars.com...though I dont have it in my hands yet). From what I remember the used TC didnt have an upper deck but some ball-cups and a threaded bar or something (thinking back a few months here...) is that the same car? Would the parts be interchangeable?
Sean
Sean
#1983
sounds like the axis2. that's last year's car. it's awesome. almost everything is compatible with yours. not belts, motor mount, or the chassis. that's about it, though. if he'll part for $40, then you've got a great deal.
#1984
Kevin K
Thanks for the tips I will start out like that and work from there.
RC
RC
#1985
Foam Asphalt setup?
I've been doing some searching, and am having a tough time locating a Mission setup sheet for foam tires on asphalt. We have a fairly large club and allow foam tires. (CORCAR in Columbus) It's the ONLY way to go out here.
I've got a decent setup on it now, but was wondering if anyone had one specificly for that?
Also, is there somewhere with a lot of Mission setup sheets?
#1986
Foam Asphalt set-up
Front-
Shocks
blue springs- 45 weight oil
#2 upper mount- inner lower mount
Chassis
Arms centered
upper arms 2 spacers behind mount/ upper hole
stock swatbar connected
2mm droop
1.5 deg chamber
0 deg toe
0 deg inboard toe
Aluminum steering knuckles using low-ball option
CRC #2114 - Front F6 X-firm-Dual Comp-28mm
Rear-
Shocks
Blue springs- 45 weight oil
#2 upper mounts- inner lower mounts
Chassis
Arms centered
upper arms in upper hole
Stock swaybar connected
2mm droop
1.5 deg chamber
3 deg toe
0 deg inboard toe
Aluminum steering knuckles using high-ball option
CRC #2110 - Front F5 X-Firm-28mm
Body- Trinity Stratus
Steering EPA on radio between %40-%60 percent (60-80 on KO mars)
gearing 28/86 w/ 17 tooth pulley small indoor asphalt
27/86 w/20 tooth pulley wide open outdoor asphalt
These foams last longer than any other I have tried, If you do apply compound only do it once....EVER! and only allow it to set for 5 min. otherwise the cr will traction roll very extra severally!!
Otherwise no compound
This set-up works very well on the small tight indoor asphalt track and the large wide open parking lot track that I race on with the only modifications being gearing and changing the Steering EPA.
God I love this car!!!!!
Shocks
Chassis
Arms centered
2mm droop
1.5 deg chamber
0 deg toe
0 deg inboard toe
Rear-
Shocks
Chassis
Arms centered
2mm droop
1.5 deg chamber
3 deg toe
0 deg inboard toe
#1987
ok, a couple of quick questions then...
Shocks:
Which piston location?
Any limiting?
Who's Oil?
Who's Springs?
(All Schumacher?)
Which one is the "stock" swaybar? I have about 6. =)
Shocks:
Any limiting?
Who's Oil?
Who's Springs?
(All Schumacher?)
#1989
Regional Moderator
Spyked: heres a place with some Mission set up sheets.
http://195.92.181.9:8090/~technicalinfo
In the left column, just click on the Mission set up sheet.
#1990
I waslooking for different sheets than those. Thanks though...
#1991
Hey Doug "Spyked" I dont know if Rob Love told you Thanks from me for lending me some batt's at the Octoberfast race in Minn. last year or not but Thanks again for the Help. And Good luck with your Mission I know the car is very good on carpet with Foam tires but have yet to race it on asphalt with Foams but I'm sure it is jut as good.
#1992
Hey Kevin, No prob on the cells. Drop me an email, I've got a few questions for ya.
[email protected]
[email protected]
#1993
You have mail
#1994
Kevin K.
I told him alright. I told him you said they sucked~ Just kidding. Doug knows you appreciate it!! How have you been doing on run time now???? If you're running electric and still having some trouble send me an e-mail at [email protected]. We have the fix now
Doug was looking pretty good with his Mission on the asphalt. It is amazing how much steering that car has with the shocks laying down. Crazy! We'll let you know how Sunday goes and might ask for some direction after racing.
Thanks for the help Kevin,
Rob Love
Rob Love
#1995
I know you lot know what your talking about so I would like to know how to get the best out of my sst sport on the smallest budjet ever. Also when it reaches it's top speed it tends turn off in one direction, I try adjusting on the reciever but it will then start veiring off in the other direction, any ideas would be much appreciated
