Xray T1
#9107
yes they should fit mike. The fk driveshafts are in fact weaker than the original evo2 ones though.
#9108
does the blade style front sway bar work on the fk or do i need to use the the wire style sway bar also which sway bar is better and most consistant
anyone else now which one works
#9110
bigl- you'll need to use the wire type sway bar for the short arms. If you have long arms you can use the blade type sway-bar personally I found them to be a pain in the butt.
#9111
Originally posted by Michal101
Hondaguy,
Those diffs look like they are the heavy spring steel diffs though.
Mike
Hondaguy,
Mike
#9112
Originally posted by Pyramid
What did I tell you all, Tony V is THE xray man
Hope you have time to explain more on differences using the following different setup,
Long upper link paralel to its lower arm (means: rear on bulkhead, front on mid shock tower holes) vs. short upper link (front standard, rear on tower with that option parts recently release) with a little bit angled down (inside) to its upper arms. I believe the second setup is widely used by factory drivers. Thanks
Let's distinguish between two things:
(1) the length of the upper link
(2) the angle of the upper link
Let's assume upper link and lower suspension arm are parallel to each other and have equal length. Let's also assume the camber angle is zero degrees when the car is at rest. In this case when the suspension compresses both arms will follow a similar arc. As a result the camber angle on the will stay the same, i.e. remain at zero degrees irrespective how far the suspension compresses. So, no camber change!
Now shorten the upper link to say half the previous length. Now the upper link will follow a tighter arc and therefore the will increase (i.e. top of wheel will lean in towards the car's centerline). Obviously making the top link longer than the lower suspension arm will have the opposite effect...
Now for the angle. Let's assume the link is parallel with the arm and the of the same length again. In this case the roll center is as low as it can pragmatically go given the position of the lower suspension arm. Now angle the link down towards the centerline of the car. This will have two effects:
(1) The roll center at that end of the car is raised higher!
(2) When the suspension is compressed the top of the will start lean in again (positive camber change)!
Given the above it should now be clear what the shorter and slightly angled rear upper link gives us: higher roll center and positive camber change. The higher roll center makes the car more reactive while the increased camber change minimizes the resulting loss of rear traction when cornering . This helps us destroy the competition .
#9113
Not long now till the worlds and we get to see the Xray shaft drive touring car Rick
#9114
bigl, if you go to www.wcrccc.v21hosting.co.uk/xraymod.htm
there are photos showing how you can use the blade type with short arms. I think it was posted earlier on this thread but I can't find it. I've just put shorts on my original chassis, and might try it if needed.
#9115
Originally posted by tonyv
Well, I guess I had this coming didn't I
Anyhow, thanks for the explanation. I will defintely try shorter link + angled down on the next rebuilt. EP has been very very slow in growth this year in our country. In fact already starting to fall apart. I guess others have no more reasons to compete with Xray! and all has blown their wallets for this most expensive class (competition level wise).
#9116
thanks,
#9118
Originally posted by rayhuang
Would be cool-are you talking fact or wishful thinking. Cause I'd buy one!!
Ray
Ray
#9119
Ooooooooo... Xray shaft? Now THAT would keep me from buying a TC4.
Rob
Rob
#9120
Rob
Rob
