Xray T1
#8926
Re: Re: Quick question...
Originally posted by etzkev
Actually, they will work, but not properly. Xray springs should be used.
-Kevin
-Kevin
#8927
They are too tight, and not as long as the xray ones from what I hear.
-Kevin
-Kevin
#8929
Originally posted by JDXray
You should just use the AE springs for the AE Shocks, and Xray Springs for the Xray Shocks. So it keeps everything simple and not complicating.
-Kevin
#8930
Set Up Question
I've noticed that the outside edge of my front tires are showing virutally no wear. So it would seem I'm not getting full tire contact when cornering. Can someone suggest a set-up change to help. I run on asphalt with either Sorex 32 or 36.
My current set-up:
white springs all four corners
30wt shock oil, 2 holes open
0 kick up, 0 squat
.5 camber front and rear
0 toe in
4.5mm rear RH
4.0mm front RH
My current set-up:
0 kick up, 0 squat
0 toe in
4.5mm rear RH
4.0mm front RH
#8931
For those of you asking about Precision Racing Systems gears. I'm beginning to wonder if they are still in business. I tried contacting, e-mail and phone call, them last week. I still have not recieved a response. I posted a thread asking about PRS.
http://rctech.net/forum/showthread.p...threadid=49766
#8932
yeah i got my xray from rc mushrooms but it was missing a bag of parts....it was missing screws for the steering rack and servo arm and screws and the turnbuckle for the steering rack and ball cups for the steering rack....it was all suppose to be in the bag number 6 but just wasnt......got to call xray
#8933
Re: Set Up Question
My current set-up:
0 kick up, 0 squat
0 toe in
4.5mm rear RH
4.0mm front RH
My current set-up:
0 kick up, 0 squat
0 toe in
4.5mm rear RH
4.0mm front RH
also base your camber on your tire wear.
#8934
#8935
Re: Re: Set Up Question
Originally posted by S-T-R-l-K-E-R
try josh cyruls set-up for the reedy race i use it as my baseline setup and modify it a bit for the track i run on. you can get it at www.cefx.net
#8936
Anyone hear any news or know of a part number for hard rear arms for the FK?
I for one sure think the car could benefit from them (carpet/foam).
Also-I think I read that someone was experimenting with making there own-any word on how that was done (JB Weld, epoxy CF plate???)
Thanks,
Ray
Thanks,
Ray
#8937
Hey guys - I am looking for some info on the X-Rays. I currently run a Losi XXX-S (non graphite, even) and had been planning on just upgrading it to full graphite. But most of the guys I race with have switched to X-Ray, so that has me looking at them.
What is the difference in the T1R, T1FK (factory kit?) and T1 Evo2?
#8938
Here's what I've found out through extensive research:
The TIR has a composite tub chassis with the tall gears 2.125
and the long arm suspension.
The T1FK has all the bells and whistles including lower gears 1.77, short arm suspension, front oneway diff, carbon fiber shock towers
and a bunch of option parts.
The T1EVO2 freedom of choice came with pillow ball or wishbone long arm suspension, (you could build it either way) 2.125 gears.
There's probably more but I can't think of everything right now.
maybe someone else can add anything I missed
#8940
FK also has new rear shock tower (lower CG and some new holes for camber links) and one of the most important features-a Mid Roll Center on the bulkhead.
And the drivetrain is Much lighter. Pretty much every rotating part has been shaved down to make it lighter (diffs, dogbones, axles, layshaft).
Ray
Ray
