Old 09-12-2004, 07:29 PM   #8926
Send a message via AIM to micros_rock
Default Re: Re: Quick question...
Originally posted by etzkev
Actually, they will work, but not properly. Xray springs should be used.
-Kevin
How do they not work properly?
micros_rock is offline   Reply With Quote
Old 09-12-2004, 07:31 PM   #8927
etzkev's Avatar
Send a message via AIM to etzkev
They are too tight, and not as long as the xray ones from what I hear.
-Kevin
etzkev is offline   Reply With Quote
Old 09-12-2004, 07:31 PM   #8928
JDXray's Avatar
Send a message via AIM to JDXray
You should just use the AE springs for the AE Shocks, and Xray Springs for the Xray Shocks. So it keeps everything simple and not complicating.
JDXray is offline   Reply With Quote
Old 09-12-2004, 07:38 PM   #8929
etzkev's Avatar
That is a simple and fool-proof guideline to go by! That is really the best thing to do.
-Kevin
Old 09-12-2004, 07:51 PM   #8930
Default Set Up Question
I've noticed that the outside edge of my front tires are showing virutally no wear. So it would seem I'm not getting full tire contact when cornering. Can someone suggest a set-up change to help. I run on asphalt with either Sorex 32 or 36.
My current set-up:
white springs all four corners
30wt shock oil, 2 holes open
0 kick up, 0 squat
.5 camber front and rear
0 toe in
4.5mm rear RH
4.0mm front RH
Lano is offline   Reply With Quote
Old 09-12-2004, 08:01 PM   #8931
For those of you asking about Precision Racing Systems gears. I'm beginning to wonder if they are still in business. I tried contacting, e-mail and phone call, them last week. I still have not recieved a response. I posted a thread asking about PRS.
http://rctech.net/forum/showthread.p...threadid=49766
Hondaguy is offline   Reply With Quote
Old 09-12-2004, 09:08 PM   #8932
yeah i got my xray from rc mushrooms but it was missing a bag of parts....it was missing screws for the steering rack and servo arm and screws and the turnbuckle for the steering rack and ball cups for the steering rack....it was all suppose to be in the bag number 6 but just wasnt......got to call xray
ARC/HobbyWing/ Protoform/ Team Integy/ R1 Wurks/ACTIVRC
HEWITT is offline   Reply With Quote
Old 09-12-2004, 10:57 PM   #8933
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
Default Re: Set Up Question
My current set-up:
0 kick up, 0 squat
0 toe in
4.5mm rear RH
4.0mm front RH
try josh cyruls set-up for the reedy race i use it as my baseline setup and modify it a bit for the track i run on. you can get it at www.cefx.net
also base your camber on your tire wear.
S-T-R-l-K-E-R is offline   Reply With Quote
Old 09-13-2004, 12:37 AM   #8934
That's great, I ordered mine from them and hopefully it will be here this week. Was the box sealed when you got it? Nothing worse than getting a new kit and finding pieces missing' and the whole time you're just itching to hit the track.
kevinm is offline   Reply With Quote
Old 09-13-2004, 01:38 AM   #8935
Default Re: Re: Set Up Question
Thanks I'll give this a try. I have a T1R and lack some of the adjustments but will incorporate what I can.
Old 09-13-2004, 11:00 AM   #8936
rayhuang's Avatar
Anyone hear any news or know of a part number for hard rear arms for the FK?
I for one sure think the car could benefit from them (carpet/foam).
Also-I think I read that someone was experimenting with making there own-any word on how that was done (JB Weld, epoxy CF plate???)
Thanks,
Ray
Old 09-13-2004, 01:49 PM   #8937
rctoyguy's Avatar
Trader Rating: 21 (100%+)
Hey guys - I am looking for some info on the X-Rays. I currently run a Losi XXX-S (non graphite, even) and had been planning on just upgrading it to full graphite. But most of the guys I race with have switched to X-Ray, so that has me looking at them.
What is the difference in the T1R, T1FK (factory kit?) and T1 Evo2?
Jeff
rctoyguy is offline   Reply With Quote
Old 09-13-2004, 01:58 PM   #8938
Deves's Avatar
Here's what I've found out through extensive research:
The TIR has a composite tub chassis with the tall gears 2.125
and the long arm suspension.
The T1FK has all the bells and whistles including lower gears 1.77, short arm suspension, front oneway diff, carbon fiber shock towers
and a bunch of option parts.
The T1EVO2 freedom of choice came with pillow ball or wishbone long arm suspension, (you could build it either way) 2.125 gears.
There's probably more but I can't think of everything right now.
maybe someone else can add anything I missed
Deves is offline   Reply With Quote
Old 09-13-2004, 02:12 PM   #8939
rctoyguy's Avatar
Sounds like the T1R and T1FK are about like the differences in the Losi XXX-S and XXX-S G+
Approximately...
Jeff
Old 09-13-2004, 02:25 PM   #8940
rayhuang's Avatar
FK also has new rear shock tower (lower CG and some new holes for camber links) and one of the most important features-a Mid Roll Center on the bulkhead.
And the drivetrain is Much lighter. Pretty much every rotating part has been shaved down to make it lighter (diffs, dogbones, axles, layshaft).
Ray
