The Speed Passion Thread
#7354
Software
Hey Guy's,
Just got myself a SpeedPassion GT2.1 Prostock, my question is which software do I download from the SP website?
I will be running 21.5.
Thanx in advance
Thanx in advance
#7355
#7356
#7357
http://www.speedpassion.net/en/produ...ESC&t=download
#7358
#7361
Even with the brakes set to 100% on the ESC, when you run a 21.5 or 25.5 without boost (we use both in our USGT and USVTA classes here), the brakes always seem weak. I believe it has more to do with the motor wind than the ESC itself, since a 13.5 in the same application has a good amount of braking.
#7362
Hello, anyone using 2.1 EX with 1S?
First the custom cut off only goes from 3,5v up, i want to put it in 3,2 or else he cuts very early.
No i'm running with no cut off with a 5200 lipo and when i reach half of the charge the car start to fail, i've read this ESC have a internal booster, anyone now the reason of the early fail?
#7363
#7364
Yes, now i'm running off, but the car starts to fail with half the battery.
SP2.1EX with 7,5T v3 on 1/12th car
Do you think the fail came from low voltage on the receiver? i've switched from LPF to this one because the internal booster.
#7365
What program now is used by top drivers in Modified? I hear that 323 Stock is in testing in Modi class.
But what settings, different gearing?
