Serpent 710
Originally posted by InitialD
What tires are you using? Offset ones?
Which roll center are you using? UBO/LB? I believe you would need to tighten the top rear pivot ball to the max and then set the rear camber / toe in. The minimum trackwidth I measured was 197 mm I believe. If you have different left and right rear camber, your top rear pivot ball would be screwed in differently.
If you still cannot get to the rear trackwidth, then just get the most minimum that you can get. Watch the rear dogbones. Make sure that it does not bind.
That's a sleek paint design ! Bravo. You come out with the best alternative bodyshell designs.
Originally posted by rwisejr
Nice paint job dude I like the layout.
Originally posted by hudy
i think that all the snakes will get tamed by the new v one rrr
I am becoming annoyed, not just at the repeated comments, but at having to filter out all of the unneccessary posts when reading this thread.
You're planning to race there too?
Originally posted by kreidel
Ellegi white spoked rim and Yes...I am using UBO/LB. I can get it to 199mm but that has the top smashed together....will that affect it at all?
I'll go home and check. I remember I got it at that trackwidth. What rear camber do you run?
OS carbs? Why? I think they are they smallest carbs. Not enough for Nova based engines.
STS carbs are close to ideal because STS engines work about the same as Nova engines. But one thing I found about STS carbs are that they are composite and not aluminum like Nova.
The top pivot balls should not smash together with the top arm. Else, they will bind.
I use UBO/LT with 4 deg rear camber, must cut the top arm almost 1.5mm to gain 199mm trackwidth (with GQ tires)
Originally posted by Pit-racer
True. I will be testing w/ a nelson plug this weekend, instead of the turbo.
Originally posted by GoldFinger
Just as a note.
Just as a note.
UBO / LT gives a pretty high rear roll center. How do you like it?
Originally posted by Sow&Steady
Ah, that means you created your own personal album and uploaded them there!
Re: Re: Nice shell
Originally posted by Diesel Racer
Cheers Voodo_Magic, it's Tamiya PS-41 Bright Silver.
Originally posted by JustRace
How's this for a pit babe? She's got that snake in her hands.
http://www.mytsn.com/publ/psimage.as...=10074&psid=10
Just how we want them to be ... as long as they don't race against us !?*#
