Serpent 710
#2611
Originally posted by NitroHead
Hey Harry concerning take down and rebuild time, it's at least three times faster than the R40. The 710 is made for keeping you stress free on the track. I also have the R40 (Except for the super chassis, it has every option part available to make it lighter and it is still heavier than the 710) and I sent it to my buddy in Florida who wanted to try it. The main reason I sent it away was engine access. It's impossible to remove the engine without moving the brake bracket or the radio plate. You know what it takes to get to the diffs.....
Four 3mm BH screws, one e clip plus one grub screw in the front and Four 3mm BH screws plus one grub screw on the brake pulley on the rear to change the belts.
Serpent did their homework and have created a true racers dream car. Don't wait!
Tell Ron to have yours by the register so you can start building it!
Chavo
Chavo
I think,for once in my life,I'm going to wait for the company to get the bugs out of a car before I buy it....Maybe the clutch and servo stuff is not a big issue to some,but I've been down the "first customer on the bandwagon route'' route before,esp with Serpent....I'll wait till I see the car run...and how well it holds up..For 2 years worth of testing,this car shouldn't have centax and servo issues(and whatever else is going to develop)...Just my thoughts,nothing else...
#2612
Originally posted by InitialD
Thanks Jack. But does it grip the clutchbell while it's gripping the pinions too? Like the B0513 Mugen tool?
#2613
The steering servo is no issue. Just different servos would require different linkage lengths.
Centax? I think it's more of a setup thingy than anything else.
Besides, what do you need to worry about since there is nothing that cannot be solved or answered by us here on 710 forum with input from guys all around the world and furthermore guys fromt he factory themselves? Where else can you get a forum this good?
#2614
Originally posted by clmbia45
Yes- I'm sorry my answer was ambiguous. It grips the bell, but not extremely tightly. I held it tight around the bell with needle nosed vice grips and then still had to use pliars around the outside diameter.
Of course the Mugen tool is expensive compared to the HPI one.
#2615
One thing about this clutch issue: I am getting really good at removing the engine. You can remove the engine, with the throttle linkage installed, and with both side braces and the 2 speed on the car.
#2616
Do you have this problem? A friend of mine has this same problem.
Luckily, I have to tune the"other" car with same MAX engine.
And no problem with that.
Back to my car and I found that nothing happen when I tighten/lossen the clutch. Could be wrong setting though.
But I never had this problem w/ my Impulse/705 or "other" car that I have to set personally.
I will check the tickness for this shoe and compare it with a new ones. I will let you know by tomorrow.
#2617
#2618
#2619
Originally posted by GoldFinger
.... ha ha ha. I prefer to remove the (exhaust) side braces first. Because all of my engines have "individual" engine mount.
#2620
GoldFinger, if I'm not wrong, the 710 engine mounts are the same as the 705 right? Just that the 710 one is 1 mm shorter...
Im lowering it 1.2mm in 705 and can be lowered even more in 710. Haven't try it yet, but i think should be difficult. Flywheel is close enough to brke disc.
#2621
Cool, how do you do that? I have tried and I found out that you have to take one of the side braces off to take the engine out. Would be interested to know how you do it...
#2622
The engine is disconnected from the motor mounts. The rear of the car is to the left and the engine is facing you (clutch). Move the carb linkage to the other side, elevate the rear of the engine about 30 degrees while moving the rear of the engine aft, then rotate the engine clockwise, moving the rear of the engine foreward and the flywheel will just clear the brake rotor. Lift it out!
#2623
#2624
plastics and parts sucks
just raced my 710 today....
well what the hell.. the bumper's busted... not just that cuz that one is understandable..well not really but from an accident. but dang, that's what the bumber is for. both upper and lower cracked and gone. and i even modded it to where the body post is on the upper bumper to make it stronger.
i made the front solid and the left outdrive is now gone. what the hell is wrong with this car. the metal itself....... gone. i lost the race because we need a ball diff so bad on our local track for the front... but then again, the front ball diff is not available anywhere... this sucks really bad!
i told my bro to get both of us serpents because i know for a fact that its the baddest most durable car out there... this is because there's a rookie at our local track with an impulse.. and im telling you... he never misses a board. the car is still in one peice. he's more like a durability test guy you know.
and here comes 710.. the most sophisticated design... most tunable out there. but then the parts sucks.
what the fukc just happened to sepernt!
#2625
Yup, actually im still using the 705 engine mount.
I think you need to send the mounts to a machinist to be able to ground them flat.
