Serpent 710
#1111
BTW, Master D, looks like you'll be getting to the 5000 mark tonite! hahahaha less than 1 week ago, I think you're still at 4700!!
#1112
Originally posted by lawndoggie
So Big D, will you be coming to HK anytime soon?
#1113
Originally posted by InitialD
Easy. They are actually the same size as the MTX-3 front bearing. The size is 10 x 15 x 4. You can also get it at a bearing shop. Cheaper than the LHS. I believe Speedmind also sells the 10 x 15 x 4 ceramic bearing version. I believe this you can get easily at where you are.
10x15x4....
10 is the inner dia?
15 is the outter dia?
and 4 is the thickness?
Thanks dude!
#1114
#1115
REALLY????????
REALLY????????
10x15x4....
10x15x4....
#1116
what about doggie bones? You know of any dog bones other than the hudy/serpent stuff that fits the front?
They don't have to be super strong, as I think I'll end up lossing them rather than breaking them, although I managed to do both in 2 outing! hahahahaa
Hey another question. My poor pipe.. its got dent on it.. looking bad!! I think someone told me about putting some sort of liquid in it and then put it in the freezer to "reverse" the dent??
Do you know of any ways to fix it?
#1117
Secondly, you could use cable ties to loop around the dog bones when it's installed. The other end of the cable tie can either be connected to the shock tower or any other part on the car. This way when the dogbones come out, they do not fly off. The cable tires will not allow the dogbones to fly far. You should not tighten the cable tie hard on the dogbone. Just enough to make a loop around it in order for it not to bind. This is actually what I did when I started out. When I hit the steering knuckles less, I did not use it anymore. Also, make sure the horizontal spacing of the front dogbones are not excessive. Else, put spacers in a form of fuel tubing in the one way drive cup to push the dogbone fully into the wheel side. Not too tight to bind the suspension. Just enough will do.
Put the pipe in the freezer for the whole night and bring it out afterwards. You may need to do it a few times depending on how bad the damage is. Good luck !
#1118
If it were possible to seal both ends somehow and stick the pipe in boiling water to allow the air pressure to push the dent out, that'd be ok, but I doubt you can seal the pipe effectively.
Cheers, Mark.
#1119
Originally posted by markp27
Water expands dramatically and with a very large force when frozen and you'd probably end up with a completely split pipe - I wouldn't do it.
However, I cannot say the true for an AE NTC3 pipe though... Like what you say, you'll definitely split it at the seams if you put it in the freezer !
#1120
It doesnt matter how long it in the freezer... once it is frozen the water can not expand anymore...
I do it all the time, and have never split the pipe....
If its a big dent... use water... if its only a small one, milk works well as it doesnt have as much force when expanding.
I realy dont think the air pressure with boiling will work at all.
#1121
Mark, it can be done. Someone (me ) did it before and it was successful. Of course, don't put it too long in the freezer. One night will do.
#1122
Really I once thought I would chill a bottle of beer quickly - I wanted to leave it for ten minutes to get the correct temperature. Two days later I wanted to take something out of the freezer and saw some really strange brown blob in there scared the life out of me until I realised it was the remains of the beer I wanted to chill
DON'T DRINK TOO MUCH BEER !
#1123
#1124
Well if you can wait till May of next year.. I can bring you one from HK =) under 400USD and of course you don't have to worry shipping then.
#1125
Originally posted by Diesel Racer
I can't beleive how lucky you guys are! Over here in the UK we'll pay £350 to £370 sterling which is equivalent to about $575 US Dollars, I tell you this country really sucks.
The does cost about >430 dollars... B.Schrijver got a good deal with his local LHS..... Living in the country where the Serpent is beeing made doesn't mean we get the parts any faster...... and it certainly doesn't mean we get things for cheap hahahahahaha...
That's not the Serpent way...... LOL. Money makes the world go round.....don't forget that....
