Like Tree3Likes
Tamiya TRF415
Old 11-14-2005, 01:54 AM
  #11266
TRF415boy's Avatar
Originally Posted by CND
Ohh bugger..
Do you perhapse know if any ally or steel outdrives have been made for our car?
Jack
If you wait a bit there'll be the diff for the MSX kit that'll be available soon.
TRF415boy is offline
Old 11-14-2005, 03:10 AM
  #11267
CND
Awesome, thats a releif, thanks mate. I hate it when the car breaks and im out of action till the parts come in!
Thanks again
Jack
CND is offline
Old 11-14-2005, 04:16 AM
  #11268
hi anyone know if the ta05 front knuckle fits the 415ms?
there is a alloy hopup for the ta05, was wondering if it was suitable for the 415?
Doomah is offline
Old 11-14-2005, 04:33 AM
  #11269
TRF415boy's Avatar
They'll fit on the old style suspension that comes with the standard 415, but not with the LW suspension of the MS/MSX
Old 11-14-2005, 04:41 AM
  #11270
dang. thanks
Doomah is offline
Old 11-14-2005, 05:02 AM
  #11271
maxoo's Avatar
look for Square part
maxoo is offline
Old 11-14-2005, 12:05 PM
  #11272
maxoo's Avatar
what is the part number of the gold shaft on the picture??? Is it a Tamiya part??
maxoo is offline
Old 11-14-2005, 12:31 PM
  #11273
BritRacer's Avatar
also what are the dark grey ballstuds on the steering, are they titanium??
If so, where are they available?
BritRacer is offline
Old 11-14-2005, 12:37 PM
  #11274
They are tamiya plain fluorine coated tamiya ballstuds.
Rick Draper is offline
Old 11-14-2005, 12:38 PM
  #11275
I would guess they are the florine coated aluminum ones offered by Tamiya
GroffBall is offline
Old 11-14-2005, 12:40 PM
  #11276
BritRacer's Avatar
dang, the aluminium ones I have keep snapping off, which means i am going through uprights way too quickly.
Old 11-14-2005, 12:49 PM
  #11277
Here's a website to SQUARE:
http://www.rc-square.com/
trf_racer is offline
Old 11-14-2005, 12:53 PM
  #11278
Kevin CBR's Avatar
Trader Rating: 11 (100%+)
Originally Posted by idar66
hi i used my msx with shooters spool for first time yesterday, i dont know what went wrong half way first race car starting making funny noise speed dropped right off, after inspection both outdrives had shead open, the right hand drive sharft was all eaten out as well, the only thing i can think off is that i havent fitted propley, as i was abit suspect on how the drive sharfts didnot fit right into outdrives, they were 2-3 mm inside drive cups, i was using the 46 mm sharfts as well, i also wonder if msx bulkheads a different from ms, if anyone can tell me what im doing wrong id appreciate it, before car lost speed it was really going well, id really like to get more then one run, thanks idar66
I have been trying to run a spool (always ran 1-way for outdoor asphalt). I have broken two other brands. I now tried the Shooters and broke an outdrive also. They seem the sturdiest of the three but seems spools don't like taking hits like a 1-way. For the Shooters spool, just make sure to take a small rubber or plastic end hammer and tap the outdrive in until it is all they way in. Can't wait until the Tamiya aluminum outdrives come out so I can see how quickly I can break those.
Kevin CBR is offline
Old 11-14-2005, 01:03 PM
  #11279
I use the std steel ones in the rear hub carriers of my cars for that reason. The steel ones are a shiny black color. you could also try a screw and a ball stud nut.
Old 11-14-2005, 01:36 PM
  #11280
Turbonium's Avatar
Trader Rating: 27 (100%+)
i usually use either the grey steel on the steering and rear uprights, or use an extra droop screw and the alum ball nut. the alum male thread ball studs are best used in low load spots!
Turbonium is offline
