Tamiya TRF415
#2701
The front diff from Jurgen for the 415
I have ran the diff and had NO PROBLEMS at all. Car is great with it in and there is no sign of any wear after 15+ runs. I have used a little tamiya anti-wear grease in the cups where the pins touch but that's all.
Jurgen makes great parts, his engineering is first class and the items are great. As normal he's used top grade materials. A++++ on anything he does.
Alan
Alan
#2702
Front Diff
Copied from page 69:
"This is what I used to make a diff for the front. I didn't have to go looking for bearings or many parts to do it. I used the same bearings that is in the front of the 415 bulkheads.
TAMIYA 51055 415 Diff Pully
TAMIYA 53522 F201 Unversal shaft
YOKOMO ZS-501 Diff Joints
YOKOMO ZS-506 Diff Rings
YOKOMO ZS-507 Diff Thrust Bearing Set
YOKOMO ZS-508 Diff Adjusting Kit"
I struggled to find geniune Tamiya F201 universals so I used Tobee Lightweight Aluminium ones instead.
Works a treat.
Lycan
Works a treat.
Lycan
#2703
Registered User
Originally posted by rtypec
pssst...Dave. Here's the setup from the past two weeks. Corner speed is between good-excellent but the car is very easy to drive This one's a keeper. However, it only works with mod motors and will oversteer with stock and 19T. Next weekend, I'm going to try a Quantum2 and change a few things to adapt it to 19T (time permitting). It's gonna be a TCS weekend so the track's gonna be packed and I don't want to disrupt others on who are trying to figure things out.
I noticed on your set-up sheet that you are running Tamiya 500 shock oil, would this be close to like an Associated 50wt. or perhaps an Xray/Serpent 50wt.?
Thanks,
#2704
Rod!!
PM me buddy I need some info from you ..kind of a good deal if you know what I mean
-Dave
#2707
Re: Front Diff
Works a treat.
Lycan
Works a treat.
Lycan
#2709
Does anyone shim between the bearin on the hub and the hub carrier to reduce slop in the axles? EJ told me to do this on my Evo 3 and I was wondering if the same applied on the 415. Also, where can I order the Echo belts from?
#2710
Originally posted by Hebiki
all quiet in the land of the 415?
Ni kidding. I am starting to think I killed this thread. As soon as i get the car, everyone quits talking!
#2711
Echo belts are available at R10. no photos though. just a listing.
R10 = rainbow ten = www.rainbowten.co.jp
#2713
By the way I could still use some help on a Tamiya America set up. I did not make it out last weekend and I am on vacation for the next two so It is going to be the middle of July before I finally get to run out there. Its killing me!
#2714
Kilruf posted his on Page 89 (i think its for 27T stock)
rtypec posted his on bottom of Page 90 (for mod 12x1)
hope that helps.
#2715
Cool. Thanks that does help.
