Tamiya TRF415
Is Tamiya looking at doing an one way setup for the MRE? Currently that car is a waste for me, as I run stock and a spool is a waste of time. Might look at an Evo V actually. Seen one going in stock and it is bloody quick.
hey al you may have to make some changes to the setup according to track conditions. i run that exact setup on my track but we have very high traction. the setup works great for me. smooth not twitchy at all. i dont run any sway bars though. i only goop 1/4 of the inner front tires. full rear. make sure your car is not tweaked also. if its a low traction track. try softer springs and oil. let me know how that is.
I have good sources saying that Tamiya is going to come out with one way set for the MRE. But don't know when...??
Spool vs. one-way
Originally Posted by JAY_UK
I seem to be one of the few on here who only uses the spool, try it because it works, even for 19t and 27t where you would expect it to scrub too much speed in corners but it doesnt. Trust me, i can drive this car quicker in 19t then any other car ive driven in my 10+ years of driving. Only now am i on A final pace and my driving ability has increased through the fact that this car is soooo easy to drive.
Just my 2$
R/C Tech Elite Member
Got 1 pack through my car and broke really early on my 2'nd pack at the IIC, but this car looks like its gonna be awesome, got a couple things to try out tomorrow, cant wait to hit the track!
Originally Posted by TRF415boy
They fit straight on. You'll need to use tamiya hardware to fit them on.
Paul
Originally Posted by Lonestar
ok, good start then - already have the alum balls for the top mount, could you please elaborate on how the bottom mounts are done? Same alum balls? thanks a lot!
Paul
Paul
It uses alu balls too...But those are screw in type. They are not like the top ones. The top one requires a screw to fit it to the shock towers.But not the bottom.The balls screws (no punt intented) into the arms.
Thanks all for the help!
Cheers,
Paul
Ben - thanks for your help - I happen to have a stock of tamiya blue alum balls, both the "screw on" and "screw through" from when I was looking for a set of aftermarket balljoints for my MR4-SD, so it looks like I'm fully equipped to perform the transfer - Just ordered a set of 53571 TAMIYA TRF DAMPER SET , which also includes both 2- and 3-hole pistons... I'm all set
Cheers,
Paul
Cheers,
Paul
Hope the shocks will serve you well and one day you'll jump the bandwagon and over to the blue side....!!
sticking to my FK05 for now - currently looking for a brand who doesn't release a new version of its top-line chassis every 6mths... and at the moment neither Tamiya nor Xray qualify for that criterion
Lonestar: only one option: Yok...
has anyone made an airduct yet? if so let's see them.
TRF415 MSX MRE
Jay L: I made a simple air duct with a Ride Cooling vent.. But I would be interested in seeing the version seen on the pro's cars.
By the way does any one know where I can find TRF 415 MSX MRE setup sheets. I am looking for rubber to carpet setup sheets. I am completely new to Tamiya, and have arace coming up next week. Any tips..
Thanks..
Thanks..
