BMI Racing Discussions
#1951
Originally posted by SpeediePHATT
Here is the center braced with the standoffs. If your talking about the bumper brace you might not have new enough diff cases. The new ones have the hole for the bumper brace. Youll have to get new cases.
I've converted another TC3 into the TC3 'O' and that has the newer diff cases with the hole at the front I'll have to swap them over.
Thanks guys
#1952
Tech Legend
Trader Rating: 51 (100%+)
fatbear nice job on your wins.
#1953
Re: BMI TC3 double win at New Zealands second largest meeting.
Originally posted by fatbear
Hi guys,
Well I have just got back from the "Ultimate Open" which is New Zealand's second largest on road meeting. I ended up TQing both Touring Modified and also Super Touring (Touring modified using whatever bodyshell you like. Usually Can Am style bodyshells). I then set about winning both classes and setting new track records in both classes. It would have to be my best results ever in RC car racing and I have been racing for about 18 years. The track its self is very bumpy and the ashfelt surface is like sandpaper. I used the black BMI tc3 chassis with the 3mm upper brace. We race on foam tires here as well. The car was just great and I was approx 1/2 lap up on everybody else from the start. I ended up winning 8 out of my 12 races and the ones I didn't win were because of driver error or mechanical problems. I have attached a couple of photos of the winning car and body shells.
Hi guys,
John
#1956
fatbear, check your PM please...
#1958
I got the bugs worked out of my new chassis. I had it hooked up. I was on a roll in the B-main after being late and having only one qualifier to get used to the new setup. I was smooth till the anouncer hollered "Speedie is on a 23 lap run". DOT-DOT-PIPE I was so mad at myself. That was the most consistant I have ever run, the car worked great.
And easy to setup as well. Its nice to have a flat surface to measure ride height off of.
#1960
Steering Rack
What mods are you guys making to get the nitro steering rack to work mines hits the bottom of the diff case and if you have pictures of the mods please e-mail them to me [email protected]
#1961
Re: Steering Rack
Ray
#1963
thanks those help alot
#1964
hey now that I've gorund away the diff case and the little thing on the steering rack it now hits my F block am I supposed to grind that away to
#1965
F-block
I had the same problem. I didn't end up doing the mod. I would have had to grind away enough material I was afraid the hinge pin would show...or be very thin in that area.
