XRAY T2’009
#511
ECS driveshafts
Just wanted to share a little about my first experience with the optional ECS driveshafts for the 008/009. I got an opportunity to test them last weekend, on a small, tight, high bite, indoor asphalt track, with spool/rubber tires. As expected (and hoped), the new ECS provided more initial turn in, more steering overall and more corner speed. They also reduced the spool chatter at full lock/throw. I know these things are expensive (nearly $100 US retail for the pair?!), but I highly recommend them if you're a serious racer. I don't think you'll be disappointed.
#512
Did you get the 52mm? If so does anyone know who has some in stock?
#513
I believe they are located out fo Austria and the order came to Canada within 2 weeks.
#514
#515
I run the 50mm driveshafts on my asphalt car when the track is high bite...You might want to check Nexus Racing for the parts you're needing:
http://www.nexusracing.com/index.php...sort=7a&page=2
#516
Guest
Hi,
I just finish building my Xray T2 009 EU Edition; plan to run on asphalt. I got the Hudy 1/10 All in one on order.
I will use 2S IP 3800 35C with a Tekin RS PRO.
Just wondering what gear/spur could I go for if I plan to use :
- LRP 9.5T STOCK Motor
- Tekin Redline 6.5T Motor
The track where I will go is :
http://www.youtube.com/watch?v=HWMliwBi_Rg
Thanks a lot for the help,
Cédric
Cédric
#517
Hi,
Cédric
Cédric
Too much zooming in, blur, shaking... *hurl*
#518
Guest
#520
#521
Guest
Hi,
I'm running a 84 SPUR on a t2 eu 009 with rubber tyres.
How can I know the good FDR in order to choose the pinion size depending on the number of turns of my motor ?
I plan to go for a 9.5T stock LRP and 6.5T Tekin Redline series
Many thanks
Cédric
Many thanks
Cédric
#524
I bought a 007 multi diff and ordered the 008 multi diff interior and swapped them works perfect...
#525
I find the Novak recommendations to be safe starting points....
