1/10 R/C F1's...Pics, Discussions, Whatever... >
Like Tree2923Likes
Old 04-13-2013, 10:07 PM
  #7726
edhchoe's Avatar
Trader Rating: 41 (100%+)
Originally Posted by InspGadgt
TCs are double deck chassis and they flex.
I guess a better description of what I was thinking is this...every double deck car, TC, F201, FGX, ect...has to be put up on chassis blocks and have the upper deck screws loosened to untweak the chassis. As the cars go through their paces on the track they twist and get stuck on the bulkheads and stand-offs that connect the upper and lower deck. Now with the FGX when the chassis twists, having the front suspension on the upper deck is going to do 2 things...first the tweak will be exaggerated because of the stand-offs, and 2nd the front and rear suspension will no longer be aligned.
I see. I just can't imagine where it would get tweaked. I tried twisting the chassis with force but I just can't see this car generating that much grip to exert any significant force that is heavier than what my hands can.
But anything can happen in the main.
edhchoe is offline
Old 04-13-2013, 10:22 PM
  #7727
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Waiting on decals!
MantisWorx is offline
Old 04-13-2013, 10:23 PM
  #7728
edhchoe's Avatar
Is that Hamilton driving Schumacher car?
edhchoe is offline
Old 04-13-2013, 10:32 PM
  #7729
MantisWorx's Avatar
Yea , I had to cross it up a bit it will be a W04 decaled W03 with Hamilton driving
Old 04-13-2013, 11:53 PM
  #7730
Every double deck chassis gets tweaked. It happens over time but they all get to a point where you need to put them back up on blocks and release the tension in the upper deck screws so the chassis sits flat again. Maybe if they mounted the upper deck to the bulkheads with some sort of pivot it wouldn't happen but that would just add too much un-needed weight.
InspGadgt is offline
Old 04-13-2013, 11:56 PM
  #7731
Originally Posted by Marty Peterson
Made up my mind! going to run the SP-1 F1 I love the front suspension design Hey Team Lotus look at this look familiar ??
Got to love it! Camber adjustment!?
Paint lab! ordering one soon!
Thanks for the heads up on this one!
I ordered one of these from Brad earlier today too Best value for the money in the F1 class for sure! That front suspension knuckle looks like the one on my CRC Xti
Old 04-13-2013, 11:58 PM
  #7732
Originally Posted by MantisWorx
Waiting on decals!
Looks good man...which body and wings did you use?
Old 04-13-2013, 11:59 PM
  #7733
Trader Rating: 70 (100%+)
Can you take a photo without the body? I was curious what the wing/body mount area looked like compared to the older bodies. Do you know if the exotek brace will work with the new piece?
PROMODVETTE is offline
Old 04-14-2013, 05:35 AM
  #7734
Cadman1981's Avatar
Where do you guys get all these amazing decals? I ordered myself a F104 Pro v2 dark titanium, and i want to do a 2013 Ferrari f138 body, but i can't find decals...
Cadman1981 is offline
Old 04-14-2013, 05:37 AM
  #7735
MantisWorx's Avatar
Its the Tamiya F2012 kit, I just did some cosmetic grinding in the front this kit is 30g heavier than the F60 kit front wing is 8g heavier and the rear wing is 3g lighter.
I am pretty sure its not going to work, the body mount in the nose piece is countersunk. I will post a pic in a bit.
Old 04-14-2013, 06:19 AM
  #7736
Jerz616's Avatar
Trader Rating: 49 (100%+)
I used the brace on the underside instead of the top like on the F60. Works great. Just need a longer screw.
Attached Thumbnails 1/10 R/C F1's...Pics, Discussions, Whatever...-image.jpg
Jerz616 is offline
Old 04-14-2013, 06:22 AM
  #7737
Jerz616's Avatar
One more pic.
Jerz616 is offline
Old 04-14-2013, 09:08 AM
  #7738
macavant's Avatar
Trader Rating: 65 (100%+)
I get my decals from F1Paintlab (F1 and now even non-F1 liveries). BPShadow does amazing work. You might want to check with him if he has the 2013 - but here is the set for
F2012
macavant is offline
Old 04-14-2013, 11:30 AM
  #7739
Marty Peterson's Avatar
Yep Same as the Enforcer Cars I design as well.
I also like the fact you can put any of the Tamiya, Tech, TRG, and other front suspensions on this thing and that it is also all black!
I also hope to order one Monday!
Marty Peterson is offline
Old 04-14-2013, 11:52 AM
  #7740
Thanks Jerz!
