1/10 R/C F1's...Pics, Discussions, Whatever...
#4966
+ YouTube Video | |
#4967
F1 cars are fairly fragile due to them being open wheeled. If you want something for speed that is similar I'd suggest a normal pan car rather than a F1...but only if you have a surface with good grip. If you are just blasting up and down the street you will find direct drive cars are quite a handful. For street blasting get a 4wd car.
#4968
Just sharing more F1 car porn. Purists, close your eyes.
2010 Concours Winner (my friend)
2011 Concours Winner (mine)
These were the concours winners in the Tamiya Asia Cup (8 countries) for past two years. Aiming for a three-peat.
#4969
Hey Guys.
i have couple of question for the revival of my current car and the investment for future car.
1. I recently burnt esc on my f104x1. stock setup & gearing. hpi drift master 17t motor with traxxas xl-2.5 esc. it was doing fine so far. esc occasionally got hot and cut off. but it gor working momentarily. then the car jumped onto short grass by accident ad i pulled the trigger once. thats when i started seeing smoke out of the car. no visual damage but it was totally dead. is this because of the motor? If so, what would be a good replacement? I'm using ni-mh battery and I'd like to keep the budget under 60.
2. I want to get a set of motor & esc for f104w gp. was looking at speed passion because price was reasonable for me and i can play with setting using program card.
is there anything else i should anticipate with this combo like getting hot?
Thank you.
Thank you.
#4970
Best F1 car to get into the class?
This question may have been asked before, but I couldn't find it in the last 20 or so pages....What do you think is best F1 chassis for someone entering the class, running on asphalt with rubber tires? (previous TC and 1/12th experience). Guys at my local track are running the various Tamiyas and the FGX and I know there's discussion about other cars like the new Serpent being released soon. What are the pros and cons of the various F1 cars on the market? Thanks in advance
#4972
I'm sure that with modern technology, much higher speeds are possible.
I think the Serpent is going to make things interesting, but it's not out yet. Also, I don't run on rubber myself, so I can't say if a car that will work on foam will also work on rubber.
#4973
I agree, I'm amazed at the (unintentional) abuse my car F104 takes and it has very little damage. I'm running the McLaren body and thats been flipped end over end 3 times and rolled numerous times at the end of a long straight, apart from a few scratches and a loose wing (just retighten the screws) the car is pretty strong.
#4974
Any suggestions for a brushed esc for my F103 that has a lipo cutoff built in?
#4975
http://teamtekin.com/rs.html
If you have the battery sideways in the F103 you could use Mamba max Pro
#4976
Yes. From the manual "LiPo batteries can be used without worrying about deep discharging the
battery. The speed-control automatically detects when a LiPo battery is used and shuts off the motor
function before a critical low voltage for the LiPo battery is reached."
#4979
thx for the great info, it's good to know.
#4980
This statement is simply not true and is an opinion. Buy the right tires and high speed gear set for the FGX and you are good out of the box. Pick up a couple more tuning options and go even faster around the corners. And at this point, the FGX is still less expensive than a stock F104. Mind you, not the X1 or Pro variants, but those cars are expensive to start with.
