Tamiya TB-02
#527
Originally posted by izzyracer
FYI: The TB02 Steering arms are different from the EVO 3 steering arms. There is no "Plate" for the TB02. The plastic tub reinforcement goes directly on top of the steering arms and post.
#528
Ok TFR, here's what ya need:
Part# 50882 is the "King pin" that goes through the cross brace. They are basically specially shaped screws. There are also two 3mm (inner diameter??) shims, part# 50586, that fit in between the cross brace and the bell crank. The king pin goes through the center of the shim. You need two of each. The cross brace mounts on the bottom of the bellcranks. Good luck!
#530
Cool. I installed the alum bellcranks last night and they come with the hardware as well. I didn't realize that before.
#531
evo3 --> tb02
Originally posted by dsrbltoys
Thats not quite right. The bearing was a 12x6 now its 10x6.
Everything needed;
Tub 9335398 12.50
upper deck parts 51044 6.50
m parts mtr mt/steering 51045 6.50
10 x 6 bearing
Or you can substitute
alloy steering 53678 32.00
alloy mtr mt 53680 23.00
use these and you don't need to buy the m parts
Also availble
plastic shock towers, and upper sus.mt B parts 51043 5.00
stabilizer set 53677 13.00
SSG reinforcing plate 53679 13.00
TB02 shaft 50993 7.25
lt/wt shaft 53686 9.75
hope that answers all q's
Kevin
Everything needed;
Tub 9335398 12.50
10 x 6 bearing
Also availble
Kevin
i notice that the tb02 has different bumper mounts... is that included in the m parts tree? if not, which is it?
#532
Originally posted by wyd
My main argument for the SS arms is that the TB-02, 414, EVO3, Surikarn, 415, and 04 all actually use those arms so I can't see why the TB-02 can't use them. They are all using the same ones no matter what the header card says. They already make it that the )4 has every advantage known to man. Tamiya already catters to that car for TCS and don't really seem to want any other car to be fast in GT2 especially. Well they can try that but at my TCS race 2 weeks ago my TB-02 was a lap faster than any 04 on GT2 and was 4 seconds faster than any GT1 car so I'm vindacated by that. Even with that plastic tub, overweight none adjustable motor mount I laid the smackdown on the over privalidged 04.
#533
Tech Legend
Trader Rating: 51 (100%+)
It would be really fun I bet. Sure that I could learn alot about what the left coast guys are doing to their Tamiya stuff. Plus to run on the Tamiya track would be great. More than likely the best track that I would ever run on to..
#536
Wyd get yer butt out here for Nats the guys are all fun and you are right it would be the best track you ever drove on.
The worst cost for the trip is hotel and talk with a few here you could probably find a roomie to help the costs. You could Madjaclk ugly mug but he could scare the piss outta you in the Audi.
John you are probably correct on the count but it probably won't get much bigger cause Kevin has himself a honey
#539
hey guys...the new Z500 from jgtc is coming from tamiya.
http://www.tamiya.com/english/show0405/show0405.htm
#540
how does this compare to the pro kits? can it win races? i know u gotta be good driver, but for the ave racer
