TAMIYA F103 RM
Old 04-26-2009, 06:27 PM
  #1921
todd8603's Avatar
Originally Posted by stocker
My front wheels seem to have quite a lot of play, as in even after tightening the lock nut, I am still able to move the wheel in and out on the axle. Is this normal and should I shim it up? thanks!
shim em up. but equally!
todd8603 is offline
Old 04-26-2009, 10:46 PM
  #1922
Blueman Austria's Avatar
Originally Posted by silverhkswrx
i run (depending on temp outside)
35/35
35/38
38/38
Hy !
Do you mean in the front the same,or softer hardness than in the rear?
Greett Blueman
Blueman Austria is offline
Old 04-27-2009, 05:34 PM
  #1923
If your F103 has a tendency to spin out on throttle at the tighter corner exits, what would be the first thing to adjust apart from throttling s-l-o-w-l-y?
stocker is offline
Old 04-27-2009, 05:35 PM
  #1924
Did 0.5mm each side. didn't seem to affect handling!
stocker is offline
Old 04-27-2009, 06:22 PM
  #1925
Stuart Pid's Avatar
Stocker:
Loosen the diff.
Stuart Pid is offline
Old 04-29-2009, 06:25 AM
  #1926
Originally Posted by Stuart Pid
Stocker:
Loosen the diff.
OK, much better now! thanks!
I run on a low grip asphalt surface, and my car pushes (understeers) on corner entry, how do I get little more steering? Will doing the negative camber mod help?
stocker is offline
Old 04-29-2009, 08:26 AM
  #1927
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
either run softer springs or tires, or move the tie rods to the front holes to change the ackerman effect of the steering. You can also try some preload on the center shock
BP SHADOW is offline
Old 04-29-2009, 05:28 PM
  #1928
I am using the kit foams, which I read here are soft in front and medium rear IIRC? I'll get a set of the front springs to try then, I think the kit black spring is the hard one.
stocker is offline
Old 04-29-2009, 05:45 PM
  #1929
Has any one used the TRG F103 Aluminum chassis. What would be the benefit?
PIRONI is offline
Old 04-30-2009, 12:38 AM
  #1930
Matt Sunderlage's Avatar
Put on the gold springs(medium) and add like 1-2mm of prelaod and prepare to smile.
I'm going to run on asphalt for first time in 12 years next week(with foams).
103's in a parking lot = awesome racing!!!! Oh and mains will be under the lights!!
Matt Sunderlage is offline
Old 04-30-2009, 04:03 PM
  #1931
POUNDITRACING's Avatar
Looking to find a very clean used car. Anyone have any suggestions on where to get one?
POUNDITRACING is offline
Old 04-30-2009, 04:29 PM
  #1932
Trader Rating: 11 (92%+)
I am finally going to get my F103GT on the track on saturday.
My last racing experience was horrible, so I am kind of nervous.
fishymamba is offline
Old 05-01-2009, 02:20 AM
  #1933
bakaguyjean's Avatar
Its suposed to put all the weight at the bottom if you are using a LIPO,but what ends up happening if the front of the chassis bends on the first couple of hits causeing all sorts of tweak problems. Even if you never crash the chassis still bends as there isnt and suport on the front of the F103 past the servo mount.
bakaguyjean is offline
Old 05-01-2009, 02:23 AM
  #1934
How is your "T" bar set?
Old 05-01-2009, 07:55 AM
  #1935
I am using the kit 103rm T bar with 2 washers front and O ring rear. I set it as what I read from this thread, hopefully I did it the right way. Front tightened until snug, and bar cannot move side to side. Then tighten rear until it can just barely move under some force. By loosening the diff and slipping a little, I am a little better, as long as I am not too trigger happy. I understand that this is a compromise as I am using the kit med rear foams, but still spin out sometimes. I got this kit used and it has a 3 Racing oil damper on the rear and aluminum on 4 sides motor mount. I think the kit comes with the L body (with the high nose?) It has adjustable rear wing, should I adjust it to the higher downforce inclined position? I am using silver can with stock gearing.
Any advice is appreciated!
stocker is offline
