Tamiya TB-03
#2101
I'm new to Tamiya asked about a TB04 and that car has a gear issue you can't get enough gear for brushless motors. I have 3 races on my TB03 it is a great handling car. As I wrote above I have a 417v5 I race in 17.5 class. TB03 handles very similar. I race against 417 and other more modern cars and my TB is very competitive against those cars. If you can replace Phillips screws with hex's it makes my car much easier to work on.
#2103
Most of the parts that you would break ie c hubs, spindle carriers, A arms, cv axles are the same ones used in the 417. That is one of the things I like about the car I only have to carry parts for 2 different cars my 417 and TB03. I am going to build a TCS legal TB03 soon I like the way this car runs. Im replacing all the suspension parts with 417 parts. I put some 417 DCJ in the front and a 3 racing spool. My next up grade is a gear diff. Companies are making upgrades for this car still.
#2104
Thanks for the helpful info.
#2105
Is the tb03 cometetive in 21.5 against tb04 and ta06? Or what would you use in this class.
#2108
+1 TB-03 is much faster overall. A few things I do admire on the TB-04 are the flat battery tray, steering rack and finer shock position adjustment.
#2110
If you plan on running 17.5, it's not an issue because it doesn't need as high an FDR as 21.5.
I'm going to attempt to go test my TB04/TB03 "twins" (I have this thing for building identical cars) next week so hopefully I'll have something to say, but I'd be surprised to have a ton of difference considering how similar the drivetrain and suspension. But you never know till you try it.
#2111
No, I've driven the car in 17.5 and seen it in 13.5. There seemed to be a disadvantage to running the TB-04 in any class...
#2113
Motor always runs hot...
#2115
So you would take the tb03 over the ta06 as well for 21.5 with fdr 4.0?
