Losi Xcelorin Brushless
#406
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Well then double check the gear mesh, and the entire drive train. If all is good, do double check the timing. It doesn't have to be slow or hesitate to be cogging. I've had my 17.5 make that same sound in 1/12 scale. I readjusted the timing in the esc and the noise went away.
#407
R/C Tech Elite Member
#408
catchya
#410
I have a 17.5 brushless which I cannot seem to gear right in my Type R.
I currently have it geared at 72/37. Any suggestions on getting the gearing right would be appreciated as at the moment it is only running at about 540 speed.
Michael
Michael
#412
Is 19/81 alright gearing for a 6.5T on a AE B4 running on a relatively smooth, loose track?
#417
Trader Rating: 102 (100%+)
Sensor wire
I have had the same problem with a few different brand speedos, it was usually the sensor wire.
change sensor wires first.
(check loose connections of course)
then check motor.
then check motor.
#419
Ok, having a problem, I put my xcelorin into a different truck w/ different radio, and at first it worked great. Then I went to program the radio to the esc and I got nothing. It rolled the wheels forward at a slow pace. I tried rev throttle position and that didnt respond at all. It programs normally, but it doesnt accelerate. I tried to interface with pc, and it says no communication w/ esc.
Any ideas??
Any ideas??
#420
Does anyone know the bearing sizes for the xceleroin motors?
